Sturtevant Richmont Torque Wrench - is it broken?
tommydog35
I purchased a used Sturtevant Richmont ccm-f150 Torque Wrench off Ebay. It is rated for 30 - 150 ft lbs. I don't have any instructions with it.
What I have noticed is that when I turn the handle to set the Torque, there is a forceful click at every increment (e.g. it will click 150 times to reach 150 ft lbs). Also the clicks are much less smooth than say a click on a socket ratchet.
All other torque wrenches I have owned (such as a Hazet wrench) are smooth to turn the handle and don't engage a click at every increment. Do you think this wrench is broken or is this a design of Sturtevant Richmont wrenches?
Strouty
Southern Maine
Sorry Tommy, didn't mean to hijack, but I couldn't figure out what the silly guy was trying to say.
I think it could be a detent system as well. That would be kind of cool.
When you turn it to adjust the settings does it go hard, then easy, hard, then easy?
T
tommydog35
Not that I have noticed. It tends to get progressively harder as you move up the scale (particularly over 100 FT Lbs)
Strouty
Southern Maine
That makes sense, you are tightening against a spring. I was just curious if it felt like it was binding and then slipping past something. I really shouldn't even comment, but I stayed at a Holiday Inn Express last night.
T
tommydog35
Mine is the same so thats how they are supposed to be, I dont really like it though.
View media item 68079
I know what you mean about not liking it. It just feels really rough. Also the way the heads go on is a bit strange. I was expecting a release button, but I have to mess about with a pick just to get the heads off. All I can say is glad the price was almost free. Think I will stick to my Hazet torque tools.
Where did you get yours from? I think mine was probably old MOD. Which makes me wonder if they are throwing out all the bad stuff?
dutchgray
Dorset. England.
Mine was ex MOD, and was pretty cheap for what it was, just bought it because I will never have enough need for open end torque tools to buy a new set but it is better than using crows feet on a normal torque wrench.
T
tommydog35
Did you get all the attachments with with wrench when you purchased it? Also does the part I circled in red on yours also looked bashed?
T
tommydog35
I don't have one near to verify but that's likely lead melted over the adjustment to tamper-proof it. Check if it scratches easy with a pick.
Thanks for the suggestion, I will have a look at it when I get in later. It seems a crazy thing to do to "tamper proof it" How would you calibrate / adjust if you needed to?
guy48065
Calibration Lab
Historically lead was used to seal the adjustment on torque wrenches. I would melt some in a little ladle and pour it in the end of the handle to bury the adjustment nut.
Today it's usually just a sticker or a cap (or a sticker ON a cap).
Lead has a very low melting point. Hit that blob with a small torch (or even a soldering iron) and it will soften and drip out before the steel handle or tube gets hot enough to cause any problems.
I'd be guessing. I only recall having ONE SR in circulation at my company but haven't seen it come through my lab in years. Guy that owned it must have moved on.
guy48065
Calibration Lab
Well whaddya know--I do have a SR wrench diagram in my files. Looks like that seal covers an access screw that leads to an internal adjustment that applies pre-load to a linkage. Adjustment is probably trial-and-error to get the tool to agree with the reference.
  • 20170308123142.pdf
