Sub Panel Surface Mount Backer
MikeWI
WI
Hi All,
This seems like an easy question but my research is turning up conflicting answers.
I want to surface mount a 100A sub panel in garage. The spot has drywall up.
What is best to mount panel to? I’ve read that people like to put plywood backer board behind panel. If I do this, does it need to be fire rated or will any plywood do the trick?
Or should I run shallow strut across the studs and mount to that? Or directly to drywall and maybe hit a stud on one side?
dcg9381
Austin, TX
Terry D
St. Louis, MO.
Check we you local codes. We mount them right to the drywall. Use a decent anchor, a metal zip it or a toggle style anchor. There are some areas when they are mounted on a concrete wall , they would require a wood backer board.
nadogail
Coronado, CA
The requirements in my city are probably not relevant to you and your location.
A brief conversation with your local Building Department, Electrical Inspector, or a local Electrical Contractor will be a wise investment of your time.
u2slow
BC
Current code (in my area) requires fire-retardant plywood for that purpose. That said, my place is from 1973 with the only further documented renovations 25+ years ago - preceding this requirement - so I do not care about the fire rating.
I quite like the utility factor of at least 1/2" plywood surrounding a panel for fastening of cables, conduit, etc.
EDIT: I probably wouldn't bother with strut unless I had an uneven surface, or needed to pass conduit or cable behind the panel.
