Daveyhunter
- Joined
- Sep 18, 2011
- Messages
- 3
I have on a pole out side my house and on the pole is a meter under that 100 amp. main breaker
I built a detached garage 60 feet away from pole , I would like to run over head wire to garage, can't go under ground because of septic lines , but I don't mind over head and wire will be 13 to 15 feet above ground , the biggest thing I will run is welder maybe , the other tools will be a table saw and mostly hand tools, I have at my disposal a 100 amp. panel for the garage and # 2 aluminum wire tri-plex 2 coated and 1 bare all 3 the same size, I guess my question is can I run a 100 amp. sub panel off of a 100 amp. main that guess to my house with what I have, the main has a disconect.
Thank you
Dave
Thank you
Dave
