Here is some background:
I have a cabin in northern Wisconsin. I have 200 amp service to the cabin, and a 100 amp main breaker sub-panel in the garage. The sub-panel in the garage is fed with 2-2-2-4 MHF and protected in the main panel with a 70 amp breaker. The distance from the house to the garage is 48'. The garage has no big loads at all, a few light, some outlets, and 2 garage door openers. I have a 28' x 40' pole barn approx 125' from the garage, which has no power or anything else ran to it.
The plan:
What I would like to do is run some 4 x 1 AWG XHHW-2 Aluminum Building Wire, in conduit, from the garage to the pole barn. I would put a 50 amp breaker in the garage and put another 100 amp main breaker sub-panel in the pole barn. I will pond 2 ground rods at the pole barn. The load in the pole barn will just be some lights, outlets, and a garage door opener. No big tools, compressors, heaters, or anything.
My questions are:
1. Is it ok that the wire to the pole barn is bigger than the wire to the garage?
2. Does this plan sound ok?
Thanks
The plan:
My questions are:
Thanks
