Eric29
I'm placing a sub panel about 3' from my main panel. Following the good advice I received in this forum, I've decided to install a sub panel that is able to handle a 200 amp load in case I decide to upgrade the 100 amp main panel in the future.
I want 60 amps to go to the sub panel. I believe that I need three 6 gauge copper wires and one 10 gauge wire for the neutral. That could be carried in 3/4" metal conduit.
In anticipation of someday making the sub panel the main and running 100 amps back to it, I believe that I need to install 1" metal conduit to carry the copper 3-3-3-8 back to it in the future.
Am I on the right track? Should I use larger conduit for the future switch over?
Thanks.
Thanks.
