subpanel info needed
soxrule
Good morning,
This is my 1st post - let me know please if I am not following procedure:
Detached garage (12x28) is only 20 feet from house.
I am running 8/3 from main panel to garage.
Electrical needs are minimal: 6 overhead flourescent shop lights (2 switches), 1 outside outlet, 3 outside lights, garage door opener, 4-6 outlets (will run typical power tools on occasion).
I'd like to pick out the correct subpanel capable of 6-8 circuits. (Will run the 8/3 off 40 amp breaker)
Can someone please throw suggestions my way?
Thank you.
Tony Soxrule
soxrule
Thx for the suggestion... unfortunately, I already ran 80 ft of 8/3 cable through the house. Can I still use this box?
pattenp
Virginia - USA
You can still use that panel. If you know for sure you won't ever need more that 6 circuits then you can use this.....http://www.homedepot.com/p/Square-D...th-Cover-HOM612L100SCP/100190554#.Uk8LMdJONY4 . But code requires a main disconnect once you have more than 6 breakers to turn off all the power.
Edit: You can use a back fed 2pole 40A breaker in the main lug panel as a disconnect if needed.
Just to be clear ...
Use a 40A breaker in the main panel and use a 2 pole 40A breaker in the first 2 slot on the left
That only leaves you 4 slots, but if you use tandem breakers you can have 8 circuits.
soxrule
Thanks everyone for the help.
Will this unit also safely work?
Siemens 100 Amp 30-Space 30-Circuit Indoor Main Breaker Load Center
P3030B1100CU
Also, the 8/3 wire that I am running is copper. Does that make a difference with an AL box?
soxrule (they won today!)
P3030B1100CU
Why do you want such a big box when you said you only need 6 or 8 circuits. Plus the wire you have install so far (#8 copper) would never carry near enough current for 30 circuits.
The box can be made out of any approved material. The connections inside the box (and the breakers) should be compatible with both aluminum and copper wire.
The biggest difference between aluminum and copper wire is the amount of current that can safely be carried for a given distance. My recommendations were based on copper wire over a distance of 110' from panel to panel. 80', 20' underground, plus 10' to play with. Is this correct ?
soxrule
80', 20' underground plus 10 is correct.
I thought if I used this box, I would have a turn-off at the subpanel. That's what I would like... don't really need that big box.
Kevin C
Portland OR
Any 240 volt circuits will use up two spaces. You can get some that are paired with 120V breakers, allowing three circuits in two slots.
A larger panel is nice if you ever decide to expand and run a larger feed circuit. Lowes has a couple of smaller panels with a 100 amp main breaker that can be used as a disconnect.
Siemens 24-Circuit 12-Space 100-Amp Main Breaker Load Center
Item #: 374128 | Model #: P1224B1100CU
$64
http://www.lowes.com/pd_374128-1318-P1224B1100CU_1z0yt2q+1z10wgm+1z140f2__?productId=3532944&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1%26page%3D1&facetInfo=Main%20breaker|Siemens
OR
Siemens 20-Circuit 10-Space 100-Amp Main Breaker Load Center (Value Pack)
Item #: 94657 | Model #: E1020MB1100FCGP
3.5 / 5
2 reviews | Write a review
$62.00
http://www.lowes.com/pd_94657-1318-E1020MB1100FCGP_1z0yt2q+1z10wgm+1z140f2__?productId=3129843&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1%26page%3D1&facetInfo=Main%20breaker|Siemens
ishiboo
Oshkosh, WI
Given 40A max and limited circuit needs, I'd go with a 6/12 as wizard said.
If you anticipate future 240v needs, a 20-circuit may be the safe way to go as you essentially are left little capacity without filling the remaining 4 slots with tandems.
I would have went with 2-2-2-4 aluminum for a similar price and had more capacity, but what's done is done :)
I was afraid you would not understand pattenp and my posts !
Use a 40A breaker in the main panel and use a 2 pole 40A breaker in the first 2 slot on the left ...
The 2 pole 40A breaker on the left side of that small panlel become the "main breaker" for that panel. The incoming power attaches to that breaker, which is why pattenp used the term "back fed", because the current is following backwards compared to what a typical breaker would see. Breaker don't care which way the current is actually flowing.
This gives you the very nice ability to "turn off" (electricians term is "disconnect") the entire subpanel for adding additional wiring. It is also a code requirement if you have over 6 circuits.
Is the wire that u ran Romex? And if so is it UF-B? In other words, is it rated for underground/wet locations?
EDIT: whoops, i see that all 3 of us posted this at the same time....
