Ok, I’m putting this in the tool discussion forum because I’m in the end asking for a tool suggestion.
I recently purchased a 2015 Explorer AWD for my kids to drive. It’s got almost 200K miles on it so I had an expectation of some work needing to be done, which I found during my test drive. It’s turning into more than I was expecting since some of the recent documented work was done with the cheapest crappiest parts you can buy and they are shot already; but that’s a somewhat different story. I mention that because it’s getting more expensive than I was planning for and I’ve got other work to move on to.
One thing I noticed during other work was that the driver’s rear knuckle has a (toe link) bushing that is shot. Grabbing 9 & 3 on the tire I can wiggle it back and forth. I’m putting new tires on it and would like to shore this up asap as I don’t want to trash a new set of tires. It would be impossible to get a good alignment anyway with the amount of movement it has in addition to it wandering around while driving.
A couple options I see:
- Ford sells the knuckle assembly with bushings installed for $506. The bushings are not available separately. At that point it feels weird to swap a hub with 200k miles considering the work taking place at that point. A new hub, while not required, is an additional $370. I can get both parts cheaper than MSRP but they are still expensive.
- Moog sells a complete knuckle/hub assembly including a new brake shield for $475 (shipped from RA). While this seems like the best choice, it again, is a cost I wasn’t planning for and don’t want to spend.
- Dorman (almost makes me throw up) sells a bushing kit for $80ish. This is obviously the most cost-effective way to solve the immediate problem. None of the other bushings seemed to be a problem at this time so I feel ok replacing just this one.
Thoughts / suggestions appreciated!
- How hard are these bushings to press in/out? In the essence of saving time, I’d love to do this on the car without removing the knuckle and bringing it to a (big) press.
- What bushing press tools are needed. I’m assuming it’s similar to a ball joint press kit with cups/drivers/threaded rod or c-frame. Tool/kit recommendations needed. Do the parts stores have them as loaners?
- Being a Minnesota crusty and rusty car does that present any issues getting a bushing out? I could heat the surrounding knuckle area with MAPP gas (all I have).
