beartoothweb
This isn't really in my garage, but if it helps get an answer, you can pretend it is. ;->
In my basement, I have a set of switches. Due to the placement (and poor planning on my part), as you walk into the area, there's no way to turn ON the light. SO, what I did was add a motion sensor-based light switch that turns on as you round the corner.
I also wanted this area dimmable as it is adjacent to the home theater. So, what I did was wire the motion sensing switch AFTER the 600W dimmer switch. So, I can turn the dimmer switch ON and adjust the DIM, then the motion sensing switch is either OFF/AUTO/ON. That functionality works perfectly.
Here's the problem - When the motion sensing switch is in the AUTO position, it appears the internal PCB is drawing current, and the overhead lights (just a 120W (2x60) fixture) are only 80% or so bright. In the ON position, you get full brightness (full voltage.)
I haven't bothered to put a meter at the fixture to see the actual voltage difference, this is inferred based on what I'm seeing.
Does anyone have any ideas as to why this would be happening? Any ideas as to how to isolate it and fix it? I don't think the switch itself is bad, I tried a 2nd one and it did the same thing.
What about rewiring it in the opposite configuration (dimmer AFTER AUTO).
Any ideas?
Thanks.
Any ideas?
Thanks.
