ckucia
Have a set of Lufkin telescoping bore gauges. Came in a plastic pouch and I discovered I have some moisture issues in the garage. They have some light rust on them, luckily mostly on the handles. But they are old and the oil inside is a little gunky.
So I've been disassembling, lightly soaking in evaporust and then am cleaning them up - one at a time so I don't mix up or loose the little pieces.
However, within the pouch there appear to be two different designs. These were my father's or grandfather's (both deceased) so I can't ask the history.
Anyhow, on one type, the locking screw is threaded on the knurled end and the rod is smooth all the way up. On the other, it's threaded at the end of the rod that goes into the head. Both have (I'm guessing) a retaining pin that sits on top of the rod on the locking screw and goes into the head to lock the anvils.
So on the former, the locking pin is visible and I can just pull it out. On the other, the pin must be inside the head, so I can't seem to get it out to release the anvils. Tried a magnet without success and tried lightly tapping while releasing the tension on the pins while squeeing the anvils. I'm guessing the gunked up grease is keeping the pin from dropping out. I put the locking screw assembly back in the handle and it doesn't appear that it goes deep enough into the head to lock the anvils, which makes me think there's a little pin in there (that and the anvils won't come out).
Was wondering if there's a trick to getting that pin out. About the only idea I have is soaking the head in penetrating oil or some sort of solvent and hoping it releases eventually, but if I can't get it out, then I'm not sure I'll ever get out all that solvent or penetrating oil.
Any ideas?
Any ideas?
