The possibilities are endless?
WaFoster01
Western Massachusetts
Hey guys. My name is Aaron Foster. I am in the early planning stages for a 30x40 Shop on my property. I'm in the hills of Western Massachusetts. I have been coming here for a while to explore ideas and get inspiration. Mostly succeeded in fueling my garage/workshop envy. I am an independent contractor/carpenter. I built my house starting in 2007 and moved here in 09. I never planned for a garage or barn. Big mistake. I didn't have the money at the time anyway. I've been working in logistics and facility maintenance for the last 20+ years. I had been pretty desperate to get out of my job for a while, but the bills were paid so I stayed. But the pandemic showed me that no business was immune to such a global shakeup. So, I figured I better find out if my idea of a carpentry side hustle had any merit. Long story short, I left last June and have been full time carpentry since. I got my CSL last June as well.
That brings me to the shop. I'm running this carpentry business from my home. I have a spare bedroom upstairs that I use to store my tools (more like an episode of hoarders). My mudroom holds all my current use tools. If the weather is nice, I can work on custom carpentry in the back yard. And when its not, I either beg for space at my neighbor's shop or buy my wife flowers, cause its man-glitter time in the living room! I've done alot of planning and searching on GJ and have settled on a 30x40 shop. I have a place picked out on my property that should fit this well. I haven't met with my excavator yet, so, we'll see what he thinks. Otherwise, I'm moving forward with the planning. I have only contacted one company so far for a Pole building kit along these lines. I called Hansen buildings and I am having them work me up a quote. I have also drawn up a sketchup design that I'll share below. While I wait for Hansen, I will be putting together a quote of my own, as if I was just going to spec out this house on my own. We'll see how all that goes.
I am planning on a 30x40x12 Pole building with attic trusses. I initially was interested in Hansen buildings because of the simplicity and speed of this type of building. But as I complicate things, I want to work up my own quote. I say complicate, because I am thinking of using barnboard siding instead of steel. Which may require me to use plywood sheathing to get the shear strength from the pole structure. And at that point what is it I am saving. Also the way Hansen spaces their trusses; I have to accommodate the floor system differently if I want to use the attic trusses. I could just go with a different pole building company that uses the same trusses spaced at 4' instead of 10' and avoid the drama. Another possibility, in terms of the loft, would be to frame the loft similar to the way Ken's Karpentry does on youtube. As my title says: The possibilities are endless. Endless until the bills roll in. Which is why I'm here.
You all have either already done this or are right in the middle of it. I am sure I am missing something. This shop will primarily be for Carpentry/woodwork. I plan to do some metal fabricating in the future. I'm not a car guy really. I do my own vehicle maintenance, but a motorshop is not my intention here. I'm more of a "Maker." A whole bunch of wide-ranging interests. And I want them all to live in this space. I have a 3 acre homestead where I grow lots of food and chickens. I've been a buckskinner for 30 years. I tan hides here at the homestead and make my own clothes. The upstairs of the shop is going to mainly be a sewing studio for all my custom sewing and artwork. But I am also getting into 3d printing and the like. So, "Clean" work upstairs and "Messy" downstairs. The lean-to if for outdoor work and to set up my hide-tanning station. It also faces the garden so I can use the lean-to as a space to do garden related work.
I included some photos of the site that I have picked out. There is a good slope to the site. And we have the usual New England stoney ground. I am planning to do a full frost wall foundation. Even though I would love to get away with something more like a Perma-column. More to discuss with the excavator. I will also do an insulated slab. Even if I don't put radiant in the slab I will, at the very least, be insulating under the slab. That about covers my plans at this point. I am waiting to meet with the excavator and I am waiting to hear back from Hansen. Let me know your thoughts and thanks if you read this whole long story. Cheers! Aaron.30x40 Shop.jpgIMG_5180.jpegIMG_5181.jpeg
d300
Oregon high desert
If you haven't already ruled out other building styles left me suggest using ICF. Yup, giant Legos.
I have erected several ICF buildings including my current home, 37 x 62 two level, and an extra 30x30 garage. These are actually pretty easy for a talented DIY guy as long as you follow the prescriptive code minimums. Personally, I don't do minimums, YRMV.
Cheap? Not in the least. Air tight? absolutely. Easy for one guy to stack and lay-in the re-bar? Yup.
Your barn wood siding would be easy to hang, you would have a very quiet, well insulated shop, easy to put windows wherever you need them...
Natty Bumppo
Savoy, MA
Also in a Western, MA hill town (Savoy). I am not a carpenter nor a contractor, but I built a barn/shop just about to your exact specs. over the past 5 or 6 years. I am a high school teacher and chipped away at it every summer. Did everything but pour the cement pad. I did use Perma-Columns. Had 17 holes drills and did not hit a single major rock...lucked out maybe? Sourced all of the materials locally. This summer I am planning on adding a shed roof like yours off the back wall.
W
WaFoster01
d300: I have considered using ICFs for the foundation. I have a friend who used them for their foundation and it is a slick solution. Its all in the mix at this point. As I get solid numbers that will help me decide how I want to proceed.
Natty Bumppo: I was actually hoping you might chime in here. I'm not too far from you in Conway. I have read through your build multiple times. I built a 12x16 cabin for a client last year and built a really nice relationship with my local sawmill. As I put together this plan, I am going to see how it pencils out to use local materials. If I can get away with perma-columns I will. But my site has a couple of spots that seem like ledge. I am not sure if you can pin those to the rock or not. All my builder colleagues are trying to convince me to stay away from posts in the ground. I'll get prices for both perma-columns and a frost wall. I'm looking for the most cost effective and stable building I can put together as quickly as possible. The sooner I can be running the business out of this thing the better. Unfortunately, there is no way I can afford to pay for someone else to build this.
d300
Oregon high desert
You could cast an insulated mono slab (frost protected shallow foundation) and not deal with rocks, and be stacking ICF blocks the next day. Spray a coat of recycled latex paint on the block to stop UV.
Yes, this sound easier than it actually is but, it is easy enough to work with since you are working with small bite-size pieces. There are several brands of ICF and some minor differences between them, so I suggest at least talking with the factory reps. There could be one in your area that can walk you through the process. One of the big advantages using ICF is that as soon as the walls are up and you get a roof you are in the dry and can work. If you want a long dissertation then let me know and I'll tell you what I learned on my builds.
Natty Bumppo has a fine looking building. If you can duplicate the assembly, you will also have a nice shop.
Natty Bumppo
Savoy, MA
Yeah, if you have ledge the Perma-columns might not work. When I bought them 6 years ago or so they were about $125 a piece. My holes went in so nicely that the guy was in and out in a few hours and charged me $200.
I was in the same boat. Didn't want to pay somebody else to do this. The drawback was that I had to spread out my labor over 4 years.
Good luck with the build.
jives
Central NY
Nothing to add, but to say that I love this part of the Berkshire foothills. Spent 10 years in Amherst and Pelham, spend many a Sunday drive or bike ride through those communities. Spent my first anniversary at a B&B in Ashfield.
W
WaFoster01
Jives: Indeed, an excellent part of the country. I'm here for good. Daily drives though the hills is how I found the land I built our house on. My carpentry work takes me all through the hills. I love it!
Michigan Mike
Kalamazoo Mi.
If you are doing a full frost wall why not do stick frame. I don't see what you are saving by building pole barn style and still having a frost wall.
