i heat my shop with a modified barrel kit( no barrels cold rolled 1/4 in plate) i am using the door off an old Sotz kit. They are no longer in business but at one time offered a thermostat that fit in the draft hole that worked on a coil i presume that when the fire was closer to the door would shut the air down some and open more as the door area cooled off when the wood burned farther from the door. Does any one know where i might be able to find one of these or something compatible?
