Thin metric wrenches
bmwpower
As thin as possible, open end style. Facom makes some, but does anyone else?
Would have been nice a couple of times ago to have a set.
Blacknwhitepit
Eastern Tennessee
Snap on Used to make them, I had a set.
Yup.
http://buy1.snapon.com/catalog/item...3&group_ID=561&store=snapon-store&dir=catalog
-BWP
tony p
London UK
When I needed a really thin wrench in a really big size (for a lock-nut on my steering rack thrust bearing in that instance), the best thing I found at a vaguely sensible price (and a sensible overall size) was a Campagnolo bottom bracket spanner (for cycles). I guess it depends what you actually want to, as to whether bike tools would be suitable for you.
Uncle Buck
Kansas
I never understood why Sears never began offering a like set in metric. I have had the standard set for years and only a few months back finally encountered an application where only my tappet wrenches would fit and work. If I bought a truck brand set I promise you Sears would begin offering them in about 5-10 years following my purchase! At least that is what has always happened in the past.
bmwpower
I actually only need one size now...16mm for BMW sway bar brackets. I've gotten by with a thicker one to date, but I'm always waiting for the boot the rip on me. Figured I might as well get it while I'm thinking of it.
fourfeathers
QUAD CITIES, IL
Wouldn't a 5/8 from your standard thin set get it done? Should be "close enough".
MAD
Western MA
My thin wrenches are an assortment -ground down, Japanese motorcycle tool kit wrenches, Grinder/power tool spindle wrenches, and a few German made single and double open end wrenches.
I noticed a while back that Stanley/Proto expanded its offering of thin wrenches.
http://www.stanleyproto.com/xhtml/literature/ProtoUltraThinWrenches_P20712.pdf
Overstock.com has a set of import (Grip brand) thin wrenches now as well.
http://www.overstock.com/Home-Garden/Grip-16-piece-Super-Thin-Wrench-Set/2647897/product.html
TNToy
West Tennessee
Get a cheap wrench and grind it down? That's what I do usually.
A belt sander works better than a grinder. ;)
The open end of a Gearwrench is pretty thin,that's what I use for sway bar links.
A snap-on box wrench is thinner than Gearwrench or Craftsman.
BMW, if you don't have a good (Snappy, Matco, etc) open end wrench for this, I can check the head-width on a Snappy combination wrench at work tomorrow. Ever run into a european brake caliper where you needed a thin 13mm or 15mm to hold the nut while tightening the caliper bolts? A Snap-on or Matco is the only one I own that's thin enough to slide right in there.
Keep an eye on eBay. I bought my metric 10-19mm combination set for $75 shipped, because it was missing a 10mm. Then I picked up the missing wrench for ~$20 off the truck, and had a full set for about $100.
MAD
Western MA
The German brands of double open end wrenches tend to be quite a bit slimmer than the typical combination wrench. This makes a lot of sense in terms of double open end wrenches being useful in addition to having combination wrenches. I have some German WGB brand wrenches that are quite slim but I do not think this brand is commonly available in North America. My old Duro/Industro brand double open end wrenches although not pretty, tend to be slimmer than most combination wrenches. You might want to look into double open end wrenches from Heyco, Wiha, Elora, Hazet, etc. I don’t have any examples of those brands to measure though. I do have quite a few 17 mm wrenches of different brands. Here is a comparison of the thickness of the open ends. They are measured at the back of the flat since many open end wrenches taper a little at the tip. I measured the thickest jaw as well. I used 17 mm as an example since I had the most examples to measure . I do not have a Snap-on 17 mm to measure but the Snap-on wrenches that I do have tend to have the slimmest open end of all the combination wrenches but nearly the same as the gear wrench open ends.
17 MM COMBINATION WRENCHES
Gearwrench – 6.97 mm
Mac M17 CW – 7.45 mm
SK raised panel – 7.53 mm
Craftsman Pro 44907 (old SK made)- 7.73 mm
Matco AC17M2 - 7.81 mm
Cornwell CW-17 – 8.05 mm
Kobalt (older JH Williams made)- 8.25 mm
Craftsman raised panel- 8.38 mm
17 MM DOUBLE OPEN END WRENCHES
WGB (Germany) 14x17 – 5.96 mm
Duro/Indestro 16x17 41617A - 6.73 mm
Izeltas (Turkey)19x17 - 7.49 mm
Craftsman raised panel 17x 19 44508 – 8.82 mm
bmwpower
Thanks!
I tried a gear wrench, but it too was too thick for comfort.
6PTsocket
They are called tappet wrenches because they were primarily made for dealing with the thin lock nut on rocker arms. Along with the shift to metric there has also been a shift to hydraulic lifters that are self adjusting. That's my best guess. There are thin wrenches from the European manufacturers. They tend to be expensive.Just Google "slim profile metric wrenches" Sears is hardly cutting edge. Over the years Easco,SK and Armstrong (now Apex) have made their stuff. They have gone more and more to Chinese stuff. If you go that route, you might as well get it from Harbor Freight for a lot less money. The stuff is a mixed bag,some junk and some stuff that has stood up quite well.
chrisnazzy
Arizona
I know the OP is looking for metric thin wrenches but just a note.....the COO on that Craftsman thin tappet wrench set is still USA. Just read on here recently how someone picked up a set and was surprised how they were still USA and a throwback to Craftsman wrenches of back in the day.
As far as metric....quick Amazon search turned up a few. These are a little pricey but are most likely quality wrenches.
http://www.amazon.com/dp/B002FCLJS8/?tag=atomicindus08-20
VIM Tools MFW 100
7 pieces. 6mm - 19mm open end set
vimtools.com
"catalog" - go to page 20
not a CLUE... just heard of them yesterday. have an inquiry in to their sales people. ordered a piece on Ebay earlier tonight just to see what quality/workmanship looks like.
dede2897234
Northern, Ohio
chrisnazzy,
If anyone here is still interested in the Craftsman tappet wrench set, be aware that the new sets are made in China. A recent thread posting by a GJ member confirms it (post #783): LINK.
Dave
toolaholic
PA
I have the facoms. Nice wrenchrs. Used them on my brake calipers of my Yaris and the sway bar links(moogs) on my Yaris. They are strong. Thet held the nut while I torqued the sway bar links to 56lbft torque.
bonneyman
Desert SW
Yeah, I was thinking bicycle cone wrenches might fill the bill.
SantaAna12
Park cone wrenches are low torque....you prolly knew that.....and relatively soft. If strength was a goal, I would look for a stronger option.
blarf
That Facom set looks nice... but when faced with the same situation I just went with a 1/4" impact driver. It was a little more expensive, but way more useful.
