Wamsutta
The kit's drill bit and counterbore tool are square drive. How do you drive that with a standard drill chuck?
You put it in the drill just like any other bit ? I have about 15 different Timesert kits and have never used the square drive except for the taps.
Why would you want to use it in a drill, production work perhaps?
I'm afraid if I try to use the drill bit with a tap wrench, I won't be able to keep the drill bit at the correct angle. It's going to be tough enough with a hand drill. To make matters worse, the hole is not a 90 from the deck.
...What I'm not clear on is the insert length. Time-Sert says you need to have your insert .200" shorter than the hole depth for blind holes, but they say nothing about thru-holes. Can I have the insert the same length as the depth of the hole on a thru-hole application? Time-Sert says that if the last 3 threads of the insert protrude past the hole, the insert won't lock.
