Tips on painting metal
mowersplus84
Would someone please share some tips on painting metal with spray paint
Heres what i have
180 grit sandpaper
1 can of rustoleum primer
1 can of rustoleum spray paint
and tape
erty67
Heres what i have
180 grit sandpaper
and tape
i'm no expert but 180 grit sounds very rough. what are you painting?
Hammer1963
Kentucky
Depending on what you are actually painting will dictate how fine of grit sand paper you will use. If the surface will be seen and has to have good color holdout, then step you paper up to the 320-360 range.
Step one: thoroughly clean the surface with a prep-solve type of cleaner. Do not use lacquer thinner as it will leave a film on the surface. A synthetic not acrylic enamel reducer will work. For reference Dupont 3812.
Sand and re-clean with prep-solve
If possible, I use a wet on wet method.
Spray two light coats of etching primer
After ample flash time, apply your topcoat. This wet on wet application will have far superior adhesion properties vs sanding between primer and paint and better color holdout
sberry
Brethren, Michigan
Depends on what you are painting, what the intent is and what kind of service it may see. I have spray painted a lot of stuff with simple scotch brite scuff and shoot color on.
Simple scuff and shoot stuff.
Boyd
Forney, TX
a tool chest and a nice finish
Actually, 180 grit is fine for the primer coat but it will be too coarse for the top coat. After letting the primer dry, go over it with 400grit, minimum. Tack it, then spray your top coat.
Do 2 medium coats, then one heavy coat.
HMCFab9
Fox valley area, Wisconsin
Clean it before anything else is done.
clean / Prep, sand, prime, sand again, prep / clean again & paint.
Final sand should be 320 or finer. 400 would be better or a red scotchbrite pad.
