Two wires on one breaker?
Don1357
Palmer, AK
The microwave outlet (compact, about 10 amps) and the extractor fan (minimal power draw) are on separate breakers at the box. Is it kosher to put two circuits on a breaker so I can free a slot? I don't imagine the microwave/extractor fan would ever get close to 15 amps draw.
rmanrman
Only if the two circuits are on the same sized cable. Ex. 14 gauge 15 amp breaker or 12 gauge wire on 20 amp breaker.
SlappyWhite
Upper Canada
It depends on what breakers you have, some are rated for two wires others are not. If not:
-You can do a pigtail in the panel.
-You can use a half height/tandem breaker to get two circuits in the space of one.
-If the microwave outlet and extractor fan are near each other you can also just feed (fish) one from the other in the kitchen and disconnect/abandon the other line.
Jim greengo
Behind my house
Depends on what brand/model of breaker.
You can tie the 2 wires together before the breaker then run a single wire to feed both though.
