UcoatIt
[email protected]
I am finishing a new floor in the shop.
UCoatIt says their coating "resists welding splatter".
Any one have expereience with this? Thanks!
3vettesnLift
Franklin, NC
Can’t help you with an answer on your welding question, sorry. However my UCoatIt floor peeled and flaked after the third year. Was a clean floor with all the prep work done as illustrated in their instructions.
Recently moved and just finished a new 2 ½ car garage. I am not going to take a chance on the UCoatIt product.
I am still researching for the “right” product.
Good luck!
lilcuda
Bay Area, California
Good luck!
I agree. I applied UCoatIt to my garage floor when it was 3 months old. I followed the instructions to the best of my ability and I have flaking problems, too. I filed a claim with them and they said it was due to improper prep. I got a free quart of coating and 10% off subsequent orders. Big deal.
If you go with UCoatIt, have someone do it for you that has done it before and make sure you get a guarantee.
Lee
Kevin54
MEMBER EMERITUS
Urbana, Ohio
You may want to talk to Roger55 on the board also. If I remember correctly he did a detailed write up on the UCoat-it and he followed the instructions to a "T", and was way disappointed in the product.
Kevin
Hammerdown
The Motor City
My 2 cents-
Welding- in you weld above the floor about 3-4 feet you should be OK. I have burned this coating while plasma cutting on the floor, but I have burned others I have used as well and expect all epoxy would burn from this abuse. I also noticed that if you don't clean up your slag you will dull the floor with it. (I'm somewhat lazy when it comes to cleaning my garage as often as I should). Eventually after refurbishing the used and abused areas, I now lay a welding blanket down to avoid any un-necessary damage.
On a side note- I was in Indy last year for a car show and some of the guys decided to go visit the Sarges' (NHRA Champion Tony Schumacher) shop. While getting a tour I noticed the epoxy flooring. They have it in the entire workshop, fabrication, assembly areas, even where they park the rigs. I asked some questions about it before asking what they had used. The foreman said they were pleased at how the coating has held up and that they were happy with the performance of it. Since I have experience with epoxy, I asked which brand they used. The shop foreman indicated that is it was UCoat It. Since I have used this before with success, I was excited by the fact that a race shop used the same products as myself and I was able to see it in use in person. It looked better than my floor!
Do a search for UCoat It on this board, and I think you will find a lot of posts about it and other coatings members have used. I like the decal thread by Wardrum (as much for the kick azz Chevy as for the coating info).
SC-Eric
Spartanburg, SC
The key word they use is 'resistant'... which simply means that is has at least some resistance but is NOT weld 'proof'...
I've said this at least a hundred times... DON'T use coatings that contain water or solvents!!! Water and/or solvents must evaporate during the curing process. The molecules leave a trail through the coating and produce a porous or microporous film. It's like putting down a wood floor and then drilling a thousand holes in it! Each hole is an opportunity for dirt, oil, chemicals, and bacteria to attack the coating and make it subject to delamination. In addition, those holes make the film more subject to abrasive damage as well.
Use 100% Solids Technology!!!
