under slab insulation
stealman
I always read about Owens Corning foamular. The other manufacturers must make a high density foam for under slab insulation. Can anyone tell me who else makes it?
stealman
I found some factoy seconds for a good price. Its 4.5" thick. Does this thickness create any problems for under the slab and around the perimiter?
R-max has a Product called Thermasheath-3 its polyisocyanurate. They say it is 25psi and approved for under slab. Ive never heard of anyone using it. Can any one see any potential problems with using it? I beileive the polyisocyanurate is a different material from the foamular and highload.
Highbeam
Mt Rainier foothills, WA
I used Insulfoam brand EPS foam. The white stuff. I bought the 25 psi rated foam for under slabs. Since 25 psi is much stronger than all but the strongest soils, it doesn't matter how thick you install. Be sure that your subgrade is very flat when using the thick stuff. 2"would conform to slight irregularities.
There is a misconception that you must use XPS (pink or blue) under slabs. Consult the manufacturer.
stealman
Can anyone else comment on using Thermasheath-3 polyisocyanurate inder a slab on grade. The manufacturer insists that it is fine, but all the searching on the Internet says no. Its is closed cell and rmax says it can hold up to 1% moisture. It is 20psi unless it is ordered special at 25psi. I am looking at factory seconds so it will probably be the 20psi
walrus
Maine
Any foam can hold moisture. The moisture will knock down the R value but 4.5 inches is R-30 or so, depending on where you live thats a healthy R value under a slab. In my case my slab is slightly elevated above grade with lots of gravel underneath, my foam might get wet in spring but should dry out over the summer. I Think its ok I used some leftover Urethane foam under my sidewalk, its worked ok, no cracks, no heaves
pstnbly
So. Vermont
I believe that you will find the polyisocyanurate is open cell, thus not a good choice for ground contact or underslab.
