ungrounded circuits- plastic or metal junction boxes?
jdsac
I'm removing some things in the attic that were just tapped into & taped over in the attic by a previous "handyman" like knob & tube would be.
To repair these runs, I need to use junction boxes. The house is wired with mid 50's romex 12/2 no ground.
Since I can't ground a metal box, should I use plastic ones or is metal correct?
Just trying to do it correctly & safely.
Thank You!
barnjunkie
TN
Both are acceptable. Go with whatever works best and is the easiest to install.
rlitman
Long Island
Or use a Romex splice kit, and skip the box altogether (yes, these are approved for use without a box).
