JTG
I'm going to be hooking up my new (used) compressor in the next few days and I'm struggling to figure out the best way to install the lines. At one spot I have 3/4" threaded male hose coming from a backup tank. I want that to go into a T to tie into the new tank. The problem is the threaded hose end does not swivel. So if I thread the t into the hose I can't thread it into the tank. I have a similar problem going to the regulator.
The way I see it I have 4 options:
1. use copper lines to and solder connections. The problem with this option is if one of my threaded connections has a small leak I can't tighten it much because the copper line restricts the movement.
2. Use black unions. Can these work with pressure up to 175psi? I have no experience with these.
3. Hammer unions. Better than option 2? Never used them.
4. Copper compression fittings. Do they have them for 3/4" and for that pressure? I've only used them for my fridge water line.
What would you guys do?
