dwieland
I got a 1980s vintage Rockwell Unisaw on the weekend but haven't been able to properly connect a power cord. I test-wired the motor (110V 1.5hp) directly and know it works. But the proper connection of the magnetic switch eludes me. The pushbutton switches, motor terminal block, and contactor are all in a box with a clear cover that holds the power buttons and which was easy to remove by turning the two lock buttons on the cover. Inside though there's no clear indication of where the previous power connections were made. Only two terminals are marked, as far as I can tell, T1 to the motor and one of the red wires (labelled L1) on the DIL 0-11. Here are pictures of what I'm looking at:
https://picasaweb.google.com/ddwieland/Rockwell34450Unisaw02?authkey=Gv1sRgCIfluPvbxvKAuwE
The yellow twist-ons are capping the power cord leads (except the green ground that's connected to the ground screw). There are a couple of pigtails I used to test connecting to the T1 and L1, since they are the only labelled terminals. Pushing the start button made the relay chatter
but didn't power the motor. Based on what I've read on forums, I also tried connecting to L1 and the terminal beside it, assuming it's L2. Nothing at all from that arrangement.
The Klockner-Moeller DIL 0-11 has been superseded, there's no wiring diagram on the tool (because of the clear cover?), and I haven't found hookup info on the web. Can anyone tell what else I should try? Judging by the relay chatter from the first test, I don't have reason to suspect the contactor is dead. But what terminals make sense to connect?
David in Ottawa
but didn't power the motor. Based on what I've read on forums, I also tried connecting to L1 and the terminal beside it, assuming it's L2. Nothing at all from that arrangement.The Klockner-Moeller DIL 0-11 has been superseded, there's no wiring diagram on the tool (because of the clear cover?), and I haven't found hookup info on the web. Can anyone tell what else I should try? Judging by the relay chatter from the first test, I don't have reason to suspect the contactor is dead. But what terminals make sense to connect?
David in Ottawa
