Update on the shop!
Gearhead559
Columbus,ohio
i started a thread a while ago on the shop space i started out in, and i figured i would give you guys a update with some before and after pics..
where it all started
i started out with just 1800sf, but ended up having to get the other 1800 next to me.
had to take out this wall
in this room
get get stuff in!
the humble beginning's
and up to now!
mrb
that wall you cut out, did you just cut it or was an engineer consulted? Last time I saw a concrete block wall cut like that it needed steel across the top of the opening.
G
Gearhead559
Columbus,ohio
the cut out in the wall was there when i moved in. and each unit in here has 2 of them. and if you look across the top of the opening, you can see how it was engineered to be cut out. those are solid concrete blocks cross the top. and every thing is up to code. i was going to cut out the other one, but dont need to really.
