I'm looking to upgrade my panel in my garage (circa 1979) from 60 amp to 100 amp. Currently, the garage panel is fed directly from the meter so it is wired as a main panel. The house main panel is 100 amp and is fed from the meter as well. The meter is 36 feet away from the garage panel and #4 aluminum travels though conduit from the meter to the ground, a couple of inches into the ground the conduit stops and wire is buried without conduit until it gets to the garage. Once it gets to the garage a small conduit is used from the ground until it gets into the exterior wall and the conduit stops. I've read that others have used aluminum mobile home feeder cable in this forum, is that an option for me to get to 100 amps? If so, what gauge? Should I use conduit all the way, or just bury it like it currently is? Is there any other options? Thanks in advance!
