tdmanhattan
- Joined
- May 23, 2015
- Messages
- 3
Ok, this question involves a not often used cabin that is completely off the utility grid and no way for generator power to feed back in to an electric companies grid. The cabin is wired with a normal residential 220 volt, 100 amp service panel. It could be hooked to an utility company grid if there was one, but there is not. Two questions. First, my generator has a floating ground. The service panel has an earth ground. It is my understanding that the service panel's earth ground will provide the necessary ground when my generator is attached to the the cabin's electrical system. Is that correct? Second question. My generator has two 110 volt outlets. Could I use two power cords running from each 110 volt generator outlet to two different 110 volt receptacles in the house - one 110 volt receptacle that feeds off the L1 in the service panel and the other 110 volt receptacle feeding off the L2. I know that any breakers powering appliances using 220 volts would have to be thrown open. And yes, the two cords with have to be used as suicide cords. Not safe. But, would such an arrangement work?
