Uses for 4AWG AL from OH drop?
bczygan
DETROIT! Arsenal of Scrappers
I have some lengths of 4AWG Aluminum (6strand) from an overhead service drop. Some of it bare and some with black unmarked sheath.
Can I run this in PVC for an accessory building or for a welder or other branch circuit? It has been bent into a bundle and not coiled, but bends are not sharp, maybe 3" radius.
pattenp
Virginia - USA
You can use it but the problem is you can't identify the proper use without having any identifying markings on the sheathing/insulation. If there are no markings it may be wire that was stripped out of a cable assembly in which case would make it against code to use.
bczygan
One wire is solid. And I know it was overhead service because it has the drip loop attached. I don't care if it's code, just safe. Is the sheathing from OH drop OK?
billsr4
sounds like #4 triplex ,used by the power co. for service drop .
Norcal
Triplex is not designed or intended for use in conduit, use it for a overhead feed or scrap it, know of a house in Arkansas where the doofus used triplex in steel studs as-is. :(
G_P
Central CT
OH gee...wonder where this wire came from...? Hahaha. I read that other thread.
Seriously.
Hope you have some proof of ownership for that wire.
Hauling in that kind of stuff to the scrapyards here will get you a visit from the police.
Guy in my town got hauled off for trying to scrap a bunch of phone cable that he was picking up after Hurricane Irene.
