Uses's for pressure tank?
72Wagon
Virginia
Had to replace my well pressure / accumulator tank (internal bladder bad), its about 15 x 36, anyone ever come up with a alternative use for these old tanks.
I would not use it for compressor tank, it is not rated for high pressure.
Kevin
DanCo
In a house, on a block, somewhere in Queens New Yo
Split it down the middle(lengthwise) weld on some legs, hinge both halves together, add a handle, some grills, punch a couple holes for venting. And you got yourself a nice shop bbq! That's what we did using a dented fuel tank off a Mack truck.
Brad54
Cut it into fourths, and use one of those fourths on the wall behind your bench grinder to keep the sparks away from the wall and baseboards.
-Brad
rsanter
visalia ca
base tank for a parts washer
small sand blaster (cabinet)
portable BBQ
waste oil storage
bob
beelsr
NE PA, USA
FIL used the last one as a rainwater collection tank with piping to irrigate his pumpkins.
Professur
Mo-Ray-Al, K-bec, Ka-Na-Da
Slice the bottom off, weld a ring to the top and you've got a japanese gong. Paint it up, mount it on a tripod and sell it. There's a guy one Weldtalk (or summat like that, the hobart site) that does them with old O2 tanks and makes good money from them.
c39er
Seattle, Washington
I turned my old 12 gallon air tank into a rolling anvil stand. And yea I know it should be on grandma's old cherry tree stump but I still like the cherries.
