vct flooring 1 year old
jaye944
GTA, Ontario, Canada
Wow, this thread goes on and on. I would like to put my 2 cents in as I have probably laid a square mile of VCT over the years...
VCT is a durable commercial flooring that will stand up to almost anything you throw at it as long as it is cared for properly. I can give some tips about how to lay and care for it.
1> VCT will conform to the underlying subfloor over time. If you want it to look good, make sure it's smooth and fill cracks and joints with a skim coat or thin set product made for use with VCT. As far as laying it over a broom finish... It may work, but will use more glue and eat a trowel or two... Also, I imagine you would see a texture when it's shiny over time as the glue cures (and pulls the tiles down). I would use leveler (thin set made to flow and level itself) over the whole floor before trying to glue it to a broom finish.
2> VCT is easy to lay, use the right trowel, hold it at as close to perpendicular to the floor as you can, spread it leaving only what the teeth on the trowel let through (extra glue will not clear and come through joints, let the glue clear, and set the tiles tight together. A razor knife and straight edge scores tiles to cut easily and then just snap them. An easy way to cut the size of the tile that meets the wall is to set it on top of the last whole tile and lay another against the wall on top of that, score the one on the whole tile using the the other as a straight edge and snap. Don't let the one you are using as a template get stuck to the glue . For more complex obstacles, a heat gun makes it much easier to work with without breaking the tiles.
3> Work from the middle of the floor, not from a wall. Snap two chalk lines perpendicular to each other and square with the building and use that as the starting place. Don't try to end at walls with whole tiles (it seldom works out and you have a 1/4" gap that's hard to fill with tile). Walls these days are never true and straight and seldom square.
4> Use good glue, Armstrong or Roberts work well... Don't just buy the cheapest you can find.
5> Buy some extra tile and put it away, you will never be able to find something to match it exactly later.
6> Charcoal lighter fluid on a paint rag (white) works great to clean up messes you make with glue.
7> Let it cure for several days (a week if its cold) before getting wet or waxing.
8> Damp mop it and wax it with several coats of good high traffic floor wax.
9> Mop with products designed for waxed floors, many cleaners will either strip the wax or discolor it over time.
10> You can't just add wax over and over, it needs to be stripped or at least buffed before applying wax again (every 6 - 12 months depending on traffic. This will keep the wax from starting to look yellow. :shocking:
There I feel a lot better now !
stage20
pcola FL
i agree with everything but charcoal lighter fluid. youll have to clean the residue afterwards.
all i use for glue cleanup is ronsonal (yellow bottle) alcohol based lighter fluid. no further clean up. wd40 works too, as everyone has some of that, but will leave behind a shine or film that will need to be cleaned with cleaner afterwards.
good info. makes it sound too easy. :)
mbolek
I have to say that my VCT is holding up well. I use Goo be Gone to remove any excess adhesive. I had a couple of spots (under tires) that the glue squeezed through. Love the fact that it is ultra smooth and can move stuff with ease. We play a lot of ping ping and moving the table is a non issue.
Only downside is that tire marks can't be removed. I'm going to replace these sections with dark gray/black tiles to help hide the tire transfer.
Do buy extra tiles, you will need to swap out one or two at some point.
blinn
Greenville SC
I'm considering VCT in my garage and shop. I do some automotive work and woodworking in this space. My question is, I put down a Sherwin Williams epoxy about 10 years ago. It's been scraped and scarred over the years but is not lifting. The floor looks like ****! Can I just degrease and scrub the existing floor and then install on top of the aged Epoxy?
I have a section where the floor surface is rough, more than a broomed finish. If the VCT will pattern through on that area or have trouble sticking because of the rough finish, do you think I could spread a leveler on that area on top of the Epoxy or am I asking for trouble?
Thanks,
Brian
Shea
California
Sand the epoxy with 100 grit on a pole sander. It will provide enough bite for the glue. The area that is rougher than a broom finish should be hit with a grinder to smooth it out.
CobraJake
Mass
Thanks,
Brian
my installer went over spots where I had epoxy not coming up and over a year later still good.
