1jjpop
My old 2 car shop I have on the edge of town is 25+ years old.With org. siding [getting old looking] I would like to overlay with vertical steel siding. Anywhere I can get directions on how to put it on???
.If you use roofing screws there is no need to predrill and they are designed to drill their own hole. Usually installed with a 1/4 " nut driver. You can get these coloured to match your siding.
The fact that your only in 7th grade means that means your body is still growing physically (athletically) which is a good thing. Here's what you can do physically:
1.Find a ab workout you will stick to. Crunches are great when done properly to build your abs. I would workout 3-4 times a week.
Pre drill all the holes while the metal is all stacked together. This way the screws will line up. No need to snap a chalk line.
