Very low-profile flex-head ratchet
ex-x-fire
Sheboygan Falls Wi.
Yeah, its a good tool to get to hard to reach nuts 'n bolts, I wouldn't use it to break loose tight stuff on a daily basis. I wore out a couple that way.
FigureItOut
Bentonville AR
I was looking for the same thing and settled on that one also. It works just fine but I'm very interested to see if this thread comes up with a higher quality alternative in 1/4".
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
captnstabn
That ratchet is awesome. I use it often, skipping steps to remove things, because that ratchet fits where nothing else will.
dnschmidt
Phoenix, AZ
That tool is made by KABO in Taiwan. KABO is one of the highest quality tool manufacturers in Taiwan and makes most of NAPA's Carlyle tools. You're not going to find higher quality anywhere. Don't fight it, buy it.
bwringer
Indianapolis
Yep. It's a pretty high-quality piece, made in Taiwan (not China), and is a very handy tool in certain situations. Just wear a disguise or something and you'll get over the shame.
http://www.ezred.com/product/14-38-stick-combination-dr-no-bit-end/
used it at work many times. They make one as well which is only 1/4 but has both a square drive end as well as a 1/4 hex end for driver bits.
Nice find, but the ends are nowhere near as skinny as the HF version.
Fedwrench
Valley of the sun
I haven't found another brand to be thinner than the Harbor Freight version. The ez red 1/4 stick and the similar one from Gearwrench are both much thicker than the Harbor Freight model. the only option you might have would be to check franktools.com to see if a premium (aka expensive) Japanese brand offers something similar. :dunno: good luck in your quest!!
kala_azar
I have one from Cornwell I got on eBay, one end is 1/4" hex for driver bits, the other end is 1/4" square for sockets. Very high quality and occasionally indispensable. As far as COO, I'm not sure but I suspect Taiwan given its quality, and the fact that it isn't marked "USA"
CarsonConcepts
North East, MD
I have the harbor freight one, and it's worked out very well. Don't use it very often, but can be a life saver at times.
I also have these adapters from Gearwrench that I use with my normal ratcheting and flex ratcheting wrenches. They fit into a 10mm (1/4" Dr), 13mm (3/8" Dr) and 19mm (1/2 Dr.) wrench. Also comes in SAE wrench sizes. They work out great when you need a more compact package.
This being GarageJournal, I would say get both, haha.
OSULemon
Now those are cool. I love having stuff like that available when nothing else will work.
gdocktor3
Connecticut
Kobalt sells pass thru ratchet sets that are super low profile, but instead of using the actual pass thru ratchet, I use my ratchet wrenches. Here's a pic of the pass thru sockets in a ratchet wrench next to the matching standard size ratchet and shallow socket. Use with reversible ratchet wrenches and they're great. Only thing is the sockets don't lock in place like they do with the actual pass thru ratchets. Just an option...
