Vintage flat belt grinder
Sawmill7
Iron River Mi
Just picked this up at scrap yard. Anyone seen one of these? Going to use it for buffing and polishing. Any idea of rpm this should run at? Thanks for any help. Bill
slowtwitch73
Hellgate
That's nice... tool rests even.
Doubt there's any rpm it 'should' run at. Buffing and polishing is usually higher rpm.. make sure the babbit bearings and spindle are in good order and well lubed... do some test runs and check the temp.
Firebrick43
West central Indiana
I have seen some. They were designed to be used with line shafts.
More than likely they are Babbit bearings. The question is what alloy is it? Babbit can be ran at 100-1000 surface ft/min speeds depending on the alloy.
If we assume the arbor shaft diameter in the bearing block is 5/8 diameter then at 3600 rpm (what many modern bench grinders turn) the sfpm is about 530 ft/min Without knowing the alloy I would not use that speed. Without wheel guarding I would not use that speed with grinding wheels.
Many people have been maimed or killed by exploding wheels which is why guarding is now mandatory on machines with stone and vitrified wheels.
If you just run Cotton buffs 1800 rpm would give you 265 ft/min of the babbit bearings. A 8" buff would be a little slow at 1800 rpm and a 10" buff just right but don't lay into it too hard.
Sawmill7
Iron River Mi
Thanks for the replies..bearings seem real good.
Name on it is J.L.Austin MFG. No2
Milwaukee Wis. USA
Going to run it with 1725 motor with same size pulleys. Just use with cloth wheels
Made a pulley for motor today.
Sawmill7
Iron River Mi
Thanks again...ya I am actually a hit and miss collector so I know about babbit. Have to keep busy with little projects during winter as they are long here in the U.P. of Michigan
