I wanted a wall mounted power washer but most of them are commercial models starting at over 1K and all I want to do really is wash the car on weekends.
I bought this:
http://www.lowes.com/pd/Greenworks-2-000-PSI-1-2-GPM-Cold-Water-Electric-Pressure-Washer/50353386
Because it mounted on a tubular frame and looked like I could get my own tubular frame bent and mount it. I don't care about the soap reservoir so I just will cap it.
One of the very disappointing things about it was the hose reel is not really usable. You have to disconnect the hose to roll it on the wheel.
Anyone done this before because I have a few specific questions:
1. This is not a high powered washer and I need a slightly longer hose. Is pressure drop over the longer hose going to be an issue? Add maybe 15' so 40' total
2. Think the orientation matters? I was going turn it 90 degree's to mount against the wall. Tube frame attached to the wall then mount the unit to that.
3. Are the thread sizes standard and anyone sell reels with the water connection built into the spindle so I can connect to that and roll it out?
Thankfully the other side of the wall is the laundry room so just going to T off of that and come through the wall with 2 spigots.
Thanks
I bought this:
Thanks
