Luckydevil said:The one I saw at home depot sat on a wire frame and it looked like it was pretty easy to pick up and move around.
Ridgid SG4000 $79
vmo said:Do you know if this one is somehow attached to the rack, or can it be pulled off by overextending the hose?? It looks as if it fulfills the need of being up out of the way!
We had some ports installed into the garage when the whole-house system was going in, and it works GREAT. Ours is a Vacuflo, and the fact that it vents outside is priceless. I wouldn't use it for wet / funky stuff, but we still have a standard shop vac for that (haven't fired it up for 2 years now ;-)bmwpower said:How about like a whole garage vacuum, modeled after a whole house vacuum? Do they make those?
SANDOVAL said:$200-700 depending on what you want to spend. I am not sure I would put it in an atic. It would be a pain in the rear to empty the thing all though the bucket is pretty big and can take a lot of trash before emptying.
I looked at the GUV and I wanted something a little more powerful.
18' 1 1/2" hose, etc. It works OK but I grab the 6hp, 16 gal one every time if it's in the garage! The difference is HUGE between the two. A lot of the difference is the 2" hose on the bigger unit.
