I'm guessing this would be perfect if you wanted to open your own auto shop.
http://minneapolis.craigslist.org/dak/tls/5717950498.html
SNAP ON TOOLS & EQ SHOP CLOSING (Des Moines) hide this posting
•safety tips
•prohibited items
•product recalls
•avoiding scams
Selling due to Illness.
THIS ENTIRE LIST IS INCLUDED IN THE PRICE OF $55,000 - YOU PACK AND MOVE
1 Modus Sys thru 2015 for Dom, Asian and Eurp with all Connectors and Manuals
1 Master Cool Reclaimer/Recharge/Evacuate System with fresh filters/Oil and Manual
1 EETM303 Vantage Pro Graphing Meter/ALL ACCESSORIES/NEW IN CASE
1 FMC601 Brake Lathe with all attchments plus hubless chucks will service up to 2 Ton Trucks
1 PBC33A Snap On Parts Washer with Skimmer and Hot Water +Soap Cleaning System
1 Snap on Counselor II with all manuals and attachments + Rolling cart and Cover
1 Century 87600 Radiator Flush Machine operated by AIR all attchments and supplies
1 Harbor Freight 2 Ton Press with accessories
1 Strut Spring Compressor Tool
1 BC4200 Snap on Battery charger with Fast Start
2 Cherry Pickers
5 Floor Jacks - Std & Low Profile
2 EECS660 Jump N Start 660
1 YA432 Gravity Feed Sand Blaster for removing paint etc
1 Walker Air Jack - Bumper Lift just rebuilt
1 Large Bench Grinder on Big Rig Wheel for Stability
1 60 Gal Air Compressor for Shop Operation - REQ 220 Electricity
2 YA779B 80" Under Card Stands for Motor Support under Rack
1 BRN900-679 Brannick Brake Bleeder With New Bladder and all Fittings
1 Walker on the floor Trans Jack
1 Harbor Frt Wire Feed Welder with new wire and tips
1 Set Acet & Oxy Torches on Cart with accessoeries
1 Spark Plug Wall Cabinet with some inventory
1 VAC201 Standing Suction and Evac Pump
1 GLD40 Smoke Wizard Diag Machine
1 NH1725 OTC Transverse Engine Support Set
9 Assted Jack Stands
3 Creepers 2 Flat and 1 Slanted
1 JCW95AR Rolling Creeper/Chair
1 Wall Mount Hose Clamp Rack - #4 thru #30 Full of Inventory
2 Jugs 30 lb - R134 Freon
3 Hanging / Wall Mount Air Hose Reels with all Fittings
2 Service Carts 1 Heavy Duty plus 1 #BLPUHST Under Hood Truck Style
1 Kwikway "On Car Brake Lathe" for Acura & Honda (can add attachments for others)
1 X-Large Bench Vise 6" Jaws
8 Gates Hose Reels - All req Sizes - Most are Full
Various Plastic Wall Cabinets full of Fuses, Bulbs, A/C Ftgs/Electrical fittings etc
100 plus Shop Rags and Fender Covers
Asstd Funnels - all uses
Asstd Shop Labor Guides thru 2008
Asstd Approx 100 Oil Filters
1 ECUB6HO Underhood Cordless Light
1 Huge ( 13 ft x 9 ft ) Snap On Tool Box including Side Cabinets, Lockers, Risers
with lined drawers, power strips, Stainless Top and Metal Pegboard back wall
Due to size must be emptied, and torn down to move
1 CT7850 18V Cordless Impact 1/2" drive with Lithium Battery and Charger 450# torque
1 CDR6850 18V Cordless Drill 1/2" drive Nicad Battery & Charger 400 # torque
1 MG725 1/2" drive Air Impact 810# torque
2 MG325 3/8" drive Air Impact 325# torque
1 PDR3000A 3/8" drive Air Reversible Drill
1 AT811 3/8" Drive Air Angle Drill
1 FAR7000 3/8" Drive Air Ratchet
1 FAR2500 1/4" Drive Air Ratchet
1 AT118 Right Angle Die Grinder
2 PT200AL / AT115 Mini Angle Die Grinder
1 FAR2505 3/8" Drive Mini Ratchet 1.4#
1 AT192A Hi Speed Reciprocating Saw
1 PT210A Die Grinder
1 PH3050B Super Duty Air Hammer - Accessories Below
PHG94A Ball Joint & Tie Rod Seperator
PHG65A Outside Cutter
PHG88A Riveter
PHG56A Scraper
PHG61A Chisel
PH200D Quick Change Chuck Retainer
GFP22E Phillips Bit
1 KDT89101D Metric Ratcheting Line Wrench Set
1 KDT89100 Standard Ratcheting Line Wrench Set
1 SAG98500 Air Tool Oiler
1 QD2100 3//8" Fixed Head Torque Wrench - FT LB click type
1 ATECH2FR100A 3/8" Tech Angle Sealed Flex Head Torque Wrench - INCH / FT lbs
1 ATECH3FR250A 1/2" Metric Tech Angle Sealed Flex Hd Torque Wrench - INCH / FT lbs
1 QD3R150 1/2" Fixed Hd Torque Wrench - FT LB click type
1 TQFR50B 3/8" Flex Hd Torque Wrench FT LB - click type Thumb Whl Series
1 TQFR100C 3/8" Flex Hd Torque Wrench FT LB - click type Thumb Whl Series
2 TQFR250E 1/2" Flex Hd Torque Wrench FT LB - click type Thumb Whl Series
1 TECH2R100 3/8" Torque Wrench Std Angle Fixed Head INCH/FT/METRIC
1 TF528D Tube Cutter & Flaring Tool
1 TFTFM932A 3 PC Thread Restore File Set 9-32 (spark plugs etc)
Asstd Large Variety of Feeler and Measuring Gauges / Files etc
Asstd Socket/Wrench Racks including Magnetic
1 AT4101 Non-Venting Blow Gun
1 YA9417 Serpentine Belt Tensioner Tool
1 YAKS22A Butane Soldering Iron Kit
1 YAKS300 Butane Soldering Iron Kit
1 PPC210BK Punches and Chisel Set
1 PPBL30AK Bronze Punch Set
1 TDTDM117A Deluxe Master Tap & Die Set - US & Metric - BOX 1
1 TDTDM500A Deluxe Master Tap & Die Set - US & Metric - BOX 2
1 DTRMAS105 Deep Well Thread Chaser Set of 5 3/8" to 5/8"
1 RD20 Master Spindle ReThread Kit - US & Metric 21pcs
1 TA23600 Ignition Module Test Kit
1 GA295 Hinged Mirror
1 GA3645 Dial Test Indicator
1 MCAL6A Electronic Caliper
1 MIC1MB Dial Micrometer
1 MICB1B Dial Micrometer
1 EECT300HO 6 & 12 Volt Circuit Tester
1 RTemp25PB Infared Thermometer
1 YA500GM Wire Terminal Tool
1 CJ92 Battery Cable Clamp Puller
1 YA4000B Vacuum or Pressure Test Kit
1 FID8838A Injector Harness Tester
1 EEPV500 Cylinder Compression Gauge Set with Adaptors
1 EEPV511 Vacuum Pressure Gauge Set
1 EEPV507 Oil Pressure Gauge Set
1 SVTS263A Cooling System Pressure Test Kit
1 SVTA6100 Cooling System Pressure Adaptor Kit
1 OTC Power Steering Pump Pulley Set
1 ACT1300A A/C Clutch Removal Tool
1 AST263J Oil Filter Removal Set
1 OTC6489 Ford Master Cam Set
1 OTC7575 OTC Radio Removal Tool
1 AST203 AST Bolt Remover Tool (stud) 1/4" to 5/8"
1 LIL59400 Lisle Pinion Bearing Puller
1 OTC7927A OTC Steering Wheel Puller Set
1 OTC7815 OTC Steering Wheel Lock Plate Compressor
1 OTC6490 OTC Master Bearing Service Kit for FWD vehicles
1 OTC7315A OTC Tie Rod Tool
1 SAG28000 SAG Hvy Duty Automatic Logic Probe (test light)
1 POW3LS01 Power Probe Set
1 POWECT2000 Power Probe Set - Short & Open Circuit Detector
1 POW219FT Power Probe Set with Audio Beep & Light
1 LIL24610 Lisle Master Filler Spout Set
1 ST9025 Sir Tools Foldup Wire Extractor Kit
1 SAG31800 Sag Seal Puller
1 OTC6784 OTC Oil Filter Socket Kit
1 AST2101 AST Oil Filter Removal Kit
1 FLU88KT Fluke Combo Tester Kit
1 FLU333 Fluke Multimeter Tester
1 STCCM600 Sir Tools Current Clamp Meter
1 KDT3680 KD Tools Gear Wrench Serpentine Belt Tool Kit
1 FFL72520199 Fowler Magnetic Base Dial Indicator
1 HP650 Nut & Thread Setting Tool & Accessories for poly nuts
1 HP200A Rivet Tool
1 HP300 Large Blind Rivet Tool
1 YA6390 Window Holder - Suction Cups & Cable
1 BF272 Inflatable Wedge to hold window during repair
1 LPK620 Master Lock Pick Kit
1 YA331 Clip Removal Pliers
1 YA1201 Door Panel Remover
1 ASG189BR Soft Grip Trim Pad Tool
1 ASGD1BR Soft Grip Dished Trim Pad Tool
1 A159 Door Handle Tool
1 A177A Trim Pad Remover
1 A179A Trim Pad Remover
1 YA336 Body Clip Pliers
1 BF801 Heavy Duty Suction Tool
1 CG95B Steering Wheel Lock Plate Remover
1 PWC42 Wire Strippers
1 3 PC SET Power Steering & Alternator Pullers - CJ117C / CJ124A / CJ3PSA
1 SBP3 Spark Plug Boot / Wire Tool
1 YA8230 Spark Plug Boot / Wire Tool
1 S9704KFUA Universal Spark Plug Socket
1 S9706KRFUA 2 pc - 5/8" Spark Plug Socket Set
1 S9704KR 13/16" Spark Plug Socket
1 S9714MKR 14 MM Spark Plug Socket
1 S9720KA 5/8" Extra Deep Spark Plug Socket
1 S9716KL 9/16" Extra Deep Spark Plug Socket
1 S9719KA 13/16" Extra Deep Spark Plug Socket
1 SGRHT6BR Hose Pick Removal Set(Rad hoses etc)
1 SGRHTLB3BR Hose Pick Removal Set(Rad hoses etc)
1 3 PC SET PS/ALT/WP Specialty Socket/Pullers - CJ113B / S6192A / CJ117C
1 S8564B Distributor Wrench - Ford, Lincoln, Mercury
1 S9609 Distributor Wrench - V8 Chevy
1 S9626 Distributor Wrench - GM 6 cyl
1 S9707 Distributor Wrench - Ford, Lincoln, Mercury
1 S8176 Distributor Wrench - Pontiac, Oldsmobile
1 S9622 Distributor Wrench - 1997 and Later GM with V8
1 S6134 Distributor Wrench - 15mm metric various vehicles
1 EEPD500 Diesel Fuel Equipment Test Kit with additional adaptors as listed below
EEPV313A/M3542A/M3574/M3540A/M3571/M3584/M3543A/M2572/M3585/M3545B
M3569A/M3570A
1 ACT106B Expansion Tube Remover
1 ACT1009A Orifice Tube Remover
1 ACT118B Spring Lock Coupler Set
1 ACT1290B Valve Core Tool
1 ACT1370 6Pc Disconnect Set
1 TEMP10 Thermometer Set
1 ACT2105 Orifice Tube Service Set
1 YAKS32 Butane Soldering Kit
1 YA6510 Bushing Extractor Kit - Honda/Acura
1 OTC OTC Ford Traction Lock Clutch Removal Tool
1 VS36-10WW Video Scope Kit
1 OTC7134 CV Joint Spreader
1 WA7500 Strut Tool
1 A1310A Bearing Seal & Race Removal Tool
1 CJ119B Pitman Arm Tool
1 CJ952 Bearing Separators Kit
1 ANS1933A 3/4" Drive Axle Nut Socket
1 ANS1938 1/2" Drive Axle Nut Socket
1 ANS1900B 3/4 " Drive Axle Nut Socket
1 S6109A 1/2" Drive Axle Nut Socket 6 Lug GM, Ford & Dana 70
1 S8695C 1/2" Drive Axle Nut Socket 4 Lug GM, Ford & Dana 44
1 S6146 1/2" Drive Axle Nut Socket 4 Lug GM, Ford & Dana 60
1 ANS1929A 1/2" Drive Spanner Socket - use with Torque Wrench on GM, Ford & Dodge
1 305SIMMY 1/2" Drive Axle Nut Set - Metric 29-36mm
•safety tips
•prohibited items
•product recalls
•avoiding scams
2 Cherry Pickers
PHG88A Riveter
PHG56A Scraper
PHG61A Chisel
GFP22E Phillips Bit
1 HP200A Rivet Tool
M3569A/M3570A
1 WA7500 Strut Tool
