Washing machine makes panel intermittently buzz
mike93lx
Richmond, VA
My office desk is on the other side of my wall from my main panels. Whenever our clothes washer is running, I get a little buzz from the panel every 13-19 seconds.
I pulled the cover and verified that the neutral and hot for that circuit are tight, ut haven't done anything with the receptacle. House and washer are both about 18 years old.
I don't remember this beyond maybe a few weeks ago, but maybe I was missing it. Doubt that, but it's possible.
I'm going to throw a clamp meter on the hot and see if the draw is bouncing around.
Washer is functioning normally
Any ideas?
ycgoat
S.E. Va
Its odd it would be intermittent un less the washer motor is stopping and starting. Assuming the sound is coming from the panel and caused by the washing machine, you should probably remove the branch circuit breaker and look for damage or signs of arcing on the panel bus and breaker contact points.
mike93lx
Richmond, VA
You have any speakers close by?
Not really. The sound is 100% coming from the panel though.
I'll do that, thanks
I'm going to guess that it's the washer's heating element and some sort of thermostatic control.
I'll run a load on cold to confirm
rlitman
Long Island
...I'll run a load on cold to confirm
I'm not sure if that will help. Many front loading smart washing machines often use the heating element for fine temperature adjustment for more consistent performance and stain removal. It is entirely possible that even the cold setting gets some heating. Double check with the manual if you can.
If the heating circuit has issues, perhaps there's some arcing inside a burned out element (or capacitor or MOV)? Just spitballing here.
mike93lx
Richmond, VA
Interesting, thanks.
I just went through a near complete teardown to replace the spider and tub bearings... It sucked and was a ton of work. I want to keep this thing alive, but do not want to tear it down again and the heating element would require that. I wonder if unplugging it may be a slightly simpler way to confirm, although even that will ****
larry4406
Northern Virginia
I wonder if you've just got a noisy breaker. Do you have another you can swap in?
I had that in a new construction house. Would hear a buzz from the panel. Finally determined it coincided when the well pump kicked on. Electrician replaced the breaker for shits and grins as all was proper and noise went away. 🤷‍♂️
mike93lx
Richmond, VA
Huh, no ****. Never even crossed my mind. Thanks
AZ Garage
Mesa AZ
Turn off the breaker, then with a firm push, push the breaker to the ON position. Make sure it's a good solid push.
I've had a breaker go bad before. Happened to the dryer circuit breaker.
rlitman
Long Island
Is it even a
see if that breaker is warmer than the rest. If so replace it.
The breaker in my garage for the power tool outlets hums when I run a space heater for more than a few minutes (it doesn't hum right away). Being a resistive load, whatever's going on has to be inside the breaker. I don't know why it is humming, but I've checked that panel with a thermal imager, and nothing seems out of order, so I haven't bothered replacing it.
The same breaker nuisance trips every so often when I start my chop saw, but since the lights and dust collection are are different circuits, I don't mind that breaker being extra sensitive.
So yeah, it's a thing.
mike93lx
Richmond, VA
Is it even a
If my office wasn't adjacent to the panel, I probably would never have noticed and it may never have posed a real issue. But when it is quiet and I can hear this repetitive, intermittent hum... that's annoying.
And ultimately a $6 fix, once I go buy a new breaker. The swap sorted it out
APEowner
Sunny, New Mexico
I'm glad it was an easy fix.
sparky 1971
Central Iowa
Did you put in a new breaker or move the circuit to another slot that had an unused breaker in it? Whenever I get a service call for the panel buzzing, the first thing I do is pull the breaker the noise is coming from. Over 75% of the time, it's an aluminum bus bar and the stab connection has failed. I don't know how many times someone else was there before me and put in a new breaker, which solved the problem for a little while, but eventually made it worse. If there's an open slot, the circuit get's moved. There've been time where I had to install a twin when there wasn't a free space though.
mike93lx
Richmond, VA
I moved a different breaker to the same slot. I recently removed my garbage disposal, so I had that 15a unused. Washer circuit had a 20, but it's working fine, even with the heater running.
I'll grab a new 20 and put it all back.
The buss looked completely fine
I also hit every breaker in both panels with an ir thermometer and other than my surge protectors being about 10 degrees warmer, all the other breakers were within about 4 degrees of each other
