wuanzinger
- Joined
- Oct 23, 2006
- Messages
- 8
I had a contractor put a small addition (9'x14') to the back of my garage for a sandblaster and storage. He poured a new slab and extended it to form a small patio. It was graded (perhaps not enough) and there is a drain in the middle of the patio, but water leaks under the sill and is being absorbed by the pressure treated sill. I can see moisture rising up into the wall studs. Obviously, this won't last very long if this continues.
I tried sealing with roofing caulk, and it has helped a little, but it is not a permanent solution and it still leaks a little. What is the best way of fixing this? Extend the eaves? Cut a small trench in the concrete for water to run away? Should this have been built with a short concrete wall instead of the wood right on top of the slab?
Thanks for you help. Great site.
