Water proof tool box
mulepackin
Montana
I'm looking for a fairly water proof, or at least water resistant, tool box. I don't mean something that will be submerged, but something to replace my hand box, that will keep driving rain and snow out. The boxes I've used either leak around the handle and clasps, or wind driven snow and rain blows up under the lip.
Stuey
28m above sea level
What's your budget?
I saw a few Chicago cases styles on clearance for $85-$100 that would be find for small to medium sized tool assortments.
Skyline
One thing to think about with these boxes. You must have a lot of moisture absoring material inside, otherwise the contents will rust like crazy if the box is left outside. I have a watertight box that I keep on my boat, and everything metal inside rusted like crazy. Changes in temperature cause lots of condensation inside, and since it's sealed...it has no where to go. Within 4-5 months, a set of spare spark plugs I had, you could not even see the electrode.
captain pabst
probably worth it if you buy both for 250. i got one last year for 300 or so. I was / am a pro bicycle wrench (between jobs) worked as a team wrench last year. was over priced for 300, it looked identical to a friends jenson box, but was made with a much thinner plastic. the sears one i have (green, though looks the same) has chicago on the casters.
not sure about weather proof, because i drilled some holes to rivet some socket rails in. that and the craftsman logo was riveted on as well as the hinges etc. also rarely left it in the bed of my truck due to the value of what was inside. but was definately more waterproof then the bags that held my clothes.
IDASHO
Moscow, Idaho
How about ammo-cans?
100% waterproof, and VERY tough.
I just finished installing two large ones on my flatbed pickup as under-body boxes. :)
29Sedanman
Indianapolis
Not sure if they make tool boxes but Pelican cases are very nice. Not sure of theie web site. Just do a search for Pelican Cases.
Chamkila
NYC, NY
i was looking at the craigslist add and wanted to know how do you know what tool goes where? is there like a picture diagram or something?
Stuey
28m above sea level
You organize the case however way you want. Those trays are intended to be versatile and adaptable so that there doesn't have to be a fixed organizational pattern to follow.
