Wax for VCT???
ablebaker
Just finished laying my Armstrong VCT and now want to put a couple of coats of wax on it before moving all my equipment on to it. Wondered if anyone had any particular recommendations for wax. I plan to sweep it, swab it, and the put the wax on with a sponge mop. Don't have a buffer so it needs to shine without buffing.
Thanks for your suggestions.
foss
On. Canada
I would get yourself a proper mop,bucket, and pail, put down some sealer and then about 6 coats of floor wax. Just my 2 cents.
BillK
Beautiful Southern Maryland
ab,
We use a Zep product on the office floor at the shop. Cant remember the name though. See if there is a commercial janitorial supply house close by, they can hook you up with the right stuff.
Jefflitzy
Red Lake, ON
FYI
If you do not seal / wax the tiles they will shrink after a while and get gaps between them
As well wait at least 5 Days after putting them down if possible to let the glue cure properly and dry
SteveB
Okanagan Valley BC Canada
About a week after my VCT was laid I applied a sealer and then mopped on 3 coats of Armstrong S-480 polish. That was 4 years ago. I usually give it a good cleaning and apply 2 coats of S-480 in the spring and fall.
This past spring I stripped off all the build -up with a rented machine from Home Depot and then repeated the polish process.
http://www.best-price.com/product/s-480-commercial-acrylic-floor-polish-gallon/786568695/1/
I have never used a buffer and still get a real good shine.
rwhite692
Central Valley, CA
This is good info...I'm right in the middle of installing my VCT...It is not going to get any kind of regular waxing but I figure I will do the full treatment once, to seal it up real good.
SteveB
I just read your entire garage project thread. What a great tutorial for anyone attempting such a job or even considering a minor upgrade to their existing garage.
It appears that we used some similar colored tiles although my minor renovation pales in comparison.
http://www.cardomain.com/ride/281382/14
I have found the Armstrong VCT to hold up very well, no cracks or lifting. Stripping over 3 years of wax build-up was a day long job. I've learned to not put as many layers of polish down. For the first couple of years I was doing 4-5 treatments annually because I loved that glassy shine. I am learning to live with 2 applications per year.
What a magnificent garage you have plus it compliments your home and property. :thumbup:
mmhouse
Desert Southwest
I would use a commercial non-slip wax like what is used in retail environments. I'd look for it at local janitorial supply houses or online.
rwhite692
Central Valley, CA
I just finished up laying the VCT this past weekend, and afterwards I damp-mopped it twice, and applied three coats of the Armstrong Excelon floor polish (Lowe's, 18.99/gallon).
It looks like you get about 400 sq/ft per gallon (at three coats of coverage). I waited a couple of hours between each coat. I used the applicator pad (it's like a paint pad) shown resting on the bucket in the last photo. Lowes' had them right next to the polish, so that's what I grabbed...I rinsed the pad out with clean water each time I was done with a coat.
I would say that using an applicator pad is a "must" since just about anything else you could try to use would probably shed and leave fuzzies in the dried floor polish.
I did not use a polishing machine, I'm sure this stuff would buff up to a crazy shine though, and I'm really tempted to do it...a family member does have a pro floor buffer machine...Hmmmm....
I did about one third of the garage and then just need to install the window trim and baseboard. We'll see how well it holds up.
scuba0459
The Fundy shore off Nova Scotia
There are some builds on this site that are a real inspiration to me. I love the way you textured the walls and am really considering this too. It is not common here in Alberta to to texture the walls. But I am really impressed with how your floor turned out. I had decided to do VCT and turned a excel spreadsheet into my floor designer. I have been shopping around for the most floor polisher for the least amount of money but now I see that I really don't need one.
Your garage looks great.
aqr81
Central Valley, Ca.
scuba0459, please tell me more about the use of the Excel spreadsheet for the floor designer. Is there a template for that somewhere? Did you just make uniform cells size and use the color pallet to layout out designs and color patterns. Just curious.
AlphaGarage
Every Garage, AnyTown, USA
There are also epoxy products designed to coat VCT. Not only do they eliminate the stripping/waxing, they also seal the seams so no moisture can get in, and like quality epoxies they're durables, adding an extra layer of protection to the floor.
rwhite692
Central Valley, CA
Thanks Scuba for the kind words!
rwhite692
Central Valley, CA
That would be a good idea (using Excel)...I went "old school" as I was sitting in the garage with a beer...Graph paper pad and pencil, LOL....
