Weatherproof battery charger?
Zebu Fellenz
Phelps, NY
Hey Everyone,
I'm looking for an automotive 12v battery charger that's waterproof/weatherproof. I see marine chargers that are listed as waterproof, but they seem to be designed for permanent installation and I'm looking for something portable.
Right now I'm using a NOCO Genius 10 that despite the well-sealed appearance is not especially water resistant. It died after sitting out in a light rainstorm and thankfully came back to life after drying out for a few weeks.
-Thanks
dogdog
Not ctek but other brands, do what post #5 did and stuff it in the engine bay and close hood for over night charging.
Z
Zebu Fellenz
Phelps, NY
I recently bought one of these.
IP67 rated which is submerged 0.5 M for 30 minutes.
That's pretty slick. Unfortunately, it seems like all the waterproof chargers available are designed more for permanent install. Bluetooth control is also a mixed bag IMO, I suppose not having buttons/controls on the charger makes it easier to waterproof.
Z
Zebu Fellenz
Phelps, NY
I suppose I should explain why I'm looking for this thing that doesn't seem to exist.
I use the charger on a wide variety of equipment, most of it is outside while charging, some of it doesn't have a hood or other protected area to set the charger. Sometimes I'm charging batteries that are completely out in the open.
I want to not have to worry if a storm's coming or if I need to charge a battery in the rain. I think for now I'll just get a plastic toolbox for the NOCO, modify it so cables can be connected with the box closed. Size the box to also hold a jump pack, battery tester, etc so I can grab the box and hopefully have all the options at the ready.
4xdog
Santa Fe, NM
I'm a big fan of the Ctek chargers, not sure about waterproof, but I've had one in my engine bay for years without an issue.
Same here! I like CTEK and have used them outside, under a closed hood, for years. That seems to be plenty of protection for them.
cherrybomb
Near Madison Wi.
I don't know of anything on the market,but I really agree you have to build your own.Pay attention to the lid where the handles are attached,for water getting in
rust in the eye
Chicagoland
A Rubbermaid "Action Packer" tote would serve well for this. They have a lid with latches that also serve as handles. You may want to make some provision for ventilation when you do this.
bigredcornhead
Just cut slits/holes in a plastic Folgers coffee can and run wire connections inside the can. Seems to keep my chargers very dry. I've seen people use those takeout contains with same amount of success.
If you were to attach clips to that charger's lugs, it should work as a non permanent mount. Weight doesn't seem too bad for the /7 or /13 at 4 pounds. What else is there driving you away? Besides maybe price, which I can't find right now.
Based on the fins, I think that might be better at heat control than a NOCO in a box.
Leaflessshadetree
Don't ask.
The one I posted has different 12V models 7, 13, 17 or 25 Amp and 24V models 5, 8 or 12 Amp.
Prices on the 12V started around $100 I used bluetooth when I first got it (I don't recall it being necessary) but now I just plug it in and lights on the unit tell me when it is done.
Same company, more portable but IP65 rating (splash/dust proof) 12V 5Amp $85 but they have other models. They offer an optional rubber "cage" for these. https://shop.pkys.com/Victron-Energ..._LaMJ5jAwcWB-5c3Czrs7sqisdLThtnkaAihlEALw_wcB
Z
Zebu Fellenz
Phelps, NY
The more I look at it the more I like it. I was a little put off by the bluetooth but if it doesn't need to be connected to setup/use there's no real issue, so long as it works plug in & go I'm happy.
I also looked at the newer NOCO offerings and saw this:
https://no.co/genpro10x1
It'd do everything I need I'd just need to swap the ring terminals for clips.
Z
Zebu Fellenz
Phelps, NY
