what are 8pt sockets for?
Derek420
Southern Indiana
I keep getting them here and there from flea markets and have no idea what they are for but come in normal standard sizes like 9/16. What are they for in an automotive stand point other than pre hex cars like model t's and fences? Can they work on a hex? I doubt it...
D
Derek420
Southern Indiana
I have no need for them it sounds like but get them by mistake as I just buy sockets by brand .I hate when I get those or 2 of the same. But for price 1.00 a piece for wright, Armstrong ,Williams and Sk hell why not I bought them out of Wright's today and Williams kobalt I guess shouldnt gripe. They want 5 for SO sockets I bought only the new style shiney ones.
L.Cheapo
Most lawn and garden equipment used square head oil drain plugs until fairly recently.
gdocktor3
Connecticut
As mentioned they are often used as oil drain plugs on lawn & garden, as well as farm tractors and stuff like that. They are also useful when removing plugs from plumbing and heating systems or other black/iron piping. I have also used them in the past to remove really tight wing nuts because they fit perfectly across the points.
Sam'sAutoParts
Northeast PA
I actually bought of set of new Craftsman 8 point sockets a few years ago. Since then I have pieced together a second set of them for the home garage. I actually use them quite often, but I work on a lot of old junk.
Wes J
Peoria, IL
Many of my older machine tools use square head set screws and bolts. Common in late 1800's up to maybe the 1920's. My Craftsman 8-pointers make life easy on those.
Tom B.
Actually they are still used on machine tools frequently. Especially on leveling screws and other adjusters. I use 8pt sockets pretty frequently.
kctyphoon
Jersey/Staten Island
They are for anything that uses square hardware. All of the hardware we use to attach cables to poles are square.. sometimes with 8 points you'll find 2 different sizes in one socket.. one square can be 1", the other can be 1 & 1/8"..
ecotec
I used one last week when I moved my 1949 Atlas 1010 around in my garage. There are four square-head bolts that hold it to the table it lives on... The same four bolts held it to a table in the original owners basement. So, a few years ago, when I bought the drill press (when the original owner died) I used the same bolts.
I like the way they look too... Like they are saying F you to the future...
D
Derek420
Southern Indiana
Lol well I guess I have them for future reference along with your alls comments I have craftsman and weight ones all sizes. I got splines as well and haven't used them and female? Torx sockets I find alot of odd sockets and specially screwdrivers, I got to learn those next like a square and flat combined and got craftsman clutch and euro electrical kinds of sorts, mostly stuff I will maybe never need.
cliftonbros89
Missouri
I have a Williams USA set. I really like them. I use them on farm equipment. Work great for square plugs and square headed set screws. Things like that.
shockwave
Marietta,ga
More on aerograde single use fasteners also some 10 point
But yes mostly for square drive fasteners just like 12 point on 6 point
larry_g
oregon
scott78
a lot of pipe plugs require 4 points of contact whether inverted or external so 8 pt works well on pipe plugs. I have many, but i seldom use them. most people will use an adjustable wrench if they have the room.
Dave455
Sussex, England
Don't find much use for them in the automotive world, apart from brake adjusters on drum brakes!
They are, however, seriously useful in the general engineering world! I use them on lathe toolpost studs, for toolpost adjustment or any application where you have a square shaft such as tightening a machine vice!
I'm fortunate to have a substantial set of British made Britool 'bi-square' sockets, to use their catalogue name, in 1/2 drive and also a set of Snap On in 3/8 drive for the smaller sizes!
The latter are by far the best out there - in case nobody has noticed, Snap On changed their 8 point sockets to a flank drive design a few years back and they are superb!
Cope
Houston, TX
When I was selling Matco Tools, I inherited a 1/2" drive set from my predecessor. When I quit, I kept them. 3/8"-1", and appear to be Wright.
MDK22
Philadelphia, PA
8pt socket uses - Tap socket, pipe plugs (ie drain plugs, or at the end of threaded plumbing gas/water/air), square head bolts/nuts (furniture, old equipment mostly farming, old buildings), 8pt head bolt/nuts (extremely rare imho should be used in place of triple square or torx/allen), slack adjusters for air brakes (ie big rigs aka real diesels), and finally to hand to a new guy when he asks for a 3/8", 3/8" drive socket and watch him look confused.
I use them a lot at work for drain plugs and fill plugs on differentials. Because of having these i have been able to get loose stuff that on multiple occasions other shops could not. I also use them as tap sockets quite often with sliding t handles because there is not always a lot of room to get at what you are doing. They do not retain a tap but, they are normally shallower and have some play so if you are up against something else you can still use it.
