What is it?
Youngguns
Mtns of Western Maryland
They're Grip-Ons, made in Spain, labeled RR-55. I found that Blue-Point rebrands Grip-Ons in green, but I can't find these particular pliers anywhere. Anyone know what these are for?
B_Bimmer
Eastern Iowa
I don't know what they are supposed to be, but if I had them theynwould be for removing filters someone made too tight that I wasn't worried about destroying in the process.
mbshop
visalia ca
I have spent an hour looking and found nothing. Not even in their catalog. Might send them a pic and see what they say.
notlob
norcal
I found nothing even similar via google, etc search. My guess is it was specially made for a specific application, likely something similar to this - a gland nut for a hydraulic cylinder.
http://www.ebay.com/itm/H154352-New-Hydraulic-Cylinder-Gland-amp-Nut-For-John-Deere-310C-310D-410C-410D-/230784014146
:pimpflash
Farmall450
Marengo, Illinois
I could use it to Tighten/remove larger abs and pvc screw on fittings.
Those fingers look like they would fit the lugs on them.
Semi-non-scarring.
An adjustable spanner of sorts.
I don't know what it is specifically for.
But;
I recognize that lug size and type from something automotive.
Maybe 4x4 fronts or transmission innards....
I would. Like to think a filter wrench had a better gripping surface than square cog....
I'm thinking exactly this, or collars on hoses for trash pumps, etc
Y
Youngguns
Anyone have any ideas on where to find swivel pads like the ones in the attached picture? I'm thinking I can convert these pliers to something a little more useful.
IndyGarage
Indy
I've seen a tool similar for tightening specialty aircraft lock nuts - landing gear and some turbine engines use those nuts.
