We have a 200amp Main Breaker Box on a Pole. We want to run aluminum wire down to a 100amp Sub Panel approximately 200' away. What size wire should we use to minimize the drop in amperage. We will bury the wire in PVC Conduit. The Sub Panel is only going to run a few small appliances and lights. It will be powering an outdoor kitchen and a few other lights. Also how do i connect the wire in the main on the neutral bar. I am assuming the one wire will be really thick to attach to that bar which has tiny screws.
