I have been using my Weaver balancer with good success on all my vehicles so far. but I'm need to fit large cone for Toyota Tundra and Landcruiser 110mm center.
I bought this cone but as you can see it cannot go all the way in. It should be going into the center which is spring loaded with the wheel flange rest on the plate of the machine. But you guys probably knew that.
I managed with a large truck cone that came with the machine, but it is also not resting on the wheel flange only resting on the bore. I mounted it by trial and error, until the rim spins reasonably true but it's not too accurate.
Also, I am not going to use a cone from the right side, which is a hole used for center cap, also I use finger plates which makes it not an option.
I know this cone is made for another machine (The cone has a Snap on equivalent part number)
Currently the center snap ring is just 110mm or so, pretty much impossible to work for my situation. I may want to research machine that can take slightly larger cones. It would have to be different from this type of machine which is similar to Mayflower.
It would probably come with a semi-large cone that would already work. Please tell if you have experience of a machine that works with large center bore (toyota) light trucks.
