Where to get some single pane glass
Citation
Indy
I recently broke a simple storm window. The panel is 23x43" which seems bigger than what Lowe's or HD stock. Any suggestions for places to check. There is one glass so I used in the past to get a mirror but I'm interested to know if there are other low cost suggestions. I only need to glass panel, not the rest of the window.
75gmck25
Alexandria, VA
I have used a local glass store, but found that even a small pane was relatively expensive because it was in an exterior door.
Original 1940 glass pane was not safety glass, but the "professional" glass place said I needed to buy safety glass because it was one pane in a French door. The fact that there were at least 9 other panes of 1940 non-safety glass did not change their rules. I needed it done quickly, so I just went with it.
C
Citation
Indy
The storm window isn't safety glass. However, the childhood scar on my right hand reminds me why safety glass is the right call for say a storm door....
alwaysFlOoReD
Airdrie, Alberta, Canada
Go behind the glass store and look beside the dumpster. I've picked up lots of old single pane glass in aluminum frames. It's not hard to remove the frame, usually a single #6 Robertson on each end.
dscheidt
They’re right, as much I as following safety regulations bothers you. It’s been required for decades in doors, even when the original glass wasn’t tempered.
