Will a 50 AMP RV plug plug into a 4 Wire Dryer outlet?
checkthisout
Like the title says. In other words, will a 14-50r (male) plug into a 14-30r (female) outlet?
Thanks!
Charles (in GA)
50 mi south of Atlanta
It should not. The purpose of various plugs and receptacles is to prevent overloading of circuits and other dangers caused by connecting loads to a circuit that it was not designed to carry.
NEMA plug and receptacle chart.
Note that even if the X and Y blades of the connector were the same size and spacing, and the ground pin the same shape and position, the neutral on the 30 amp is a small L shaped slot, while the 50 amp uses a rather tall blade, that would not fit.
Charles
C
checkthisout
Charles
Thank you.
Haven't examined them in person. I thought maybe the middle blade of the 14-50 was thin enough to fit into the vertical part of the "L" on the 14-30. Then I could have used an over the counter 50-30 amp adapter for an RV to simplify things a bit.
I'll go ahead and make an adapter plug for my RV using a dryer cord and 30 amp rv female. Thanks!
Charles (in GA)
Thank you.
Are you saying you have a 30 amp Travel Trailer plug on your RV (120V only)???
Charles
C
checkthisout
Charles
I was going to cap one of the 110 legs and just go between the other 110 and common.
At the end of the day I gave it some more thought and installed both a dryer and an RV outlet with separate wiring and breakers. The cost difference wasn't that much.
