wiring pole building
Mike in Ohio
Canton,Ohio
When running wire in a pole building do you guys drill through the posts or do you run the wire in the gap between the the post and the osb? Between would put the wire within about 2" of the outside surface. Just wondering how you guys did yours. Mike
tdkkart
Eastern Iowa
It would depend on how you intend to finish the inside of the building, but I wouldn't run them in the gap regardless, too much chance of somebody running a screw or nail in from the outside.
Years ago when I worked for a guy that did alot of pole buildings, most we did were not intended to be insulated. We mounted the boxes to the face of the poles, ran conduit up to the bottom of the rafters and then ran the bare romex from there. Anything that ran below rafter level was done in conduit. This protected the wires where they were most likely to be damaged, but indeed did use a fair amount of extra wire, which some guys bitched about.
If you're finishing the inside, you can run the wires inside the wall following the same rules as any framed building, which means drilling the poles here and there, or run them in conduit on the surface.
Mike in Ohio
Canton,Ohio
The nail or screw from outside was what I had in mind too.Planning to frame between post with 2x3 flush with inside of post then insulate and put on osb. I think I will stay in the back 1/3 of the post then the wire won't interfere with the studs Thanks, Mike
