fotoflojoe
Searched for this topic both here and on the interwebs, found nothing that answers the question.
I'm installing eight of these in the garage:
48" Lithonia T8 strip lights.
Configuration is four rows of two continuous strips. For some reason, I'm letting myself become unsure of how to wire together the units in each strip.
The circuit's not finished yet and I want to be sure I've done it correctly before throwing the breaker!
Here's how the fixtures are wired, seems correct to me. Tell me if I'm wrong:
Power goes from panel, to switch, to fixtures.
Two fixtures in each strip; L1 = fixture 1, L2 = fixture 2
L2 mounted "continuous" to L1
Power enters L1.
Pigtail hot, neutral, and ground from L2, carry pigtails into L1
Connect L2 pig tails, L1 wires, incoming power, and outgoing power
All hots together, all neutrals together, all grounds together.
Outgoing power continues to next strip.
This should be obvious, but for some reason, the fact that they're continuous strips is throwing me a curve ball.
Thanks for any and all advice!
Power enters L1.
