Work bench material
MGUY
Hi everyone. I have a question about wood for my work bench. I have some left over pressure treated 4 x 4 posts that I would like to use. Would this type of wood be ok, or should I use something else ?
Thanks
PAToyota
South Central Pennsylvania, USA
A couple quick thoughts would be absorbing the "treatment" into your hands as you work there and the possibility of inhaling the stuff if you ever did anything that "smoked" it... I'd much prefer "clean" wood over treated for such an application.
Now if you mean for the posts and not the benchtop, I'd see no reason not to use it.
Uncle Buck
Kansas
Thanks
I think I used left over CCA 4x4 posts from another project for legs on several of my work benches and never had any kind of problem whatsoever. I think you run into more of a problem with pressure treated wood twisting when exposed to the elements for years such as decks, I have seen no such problems with the CCA I used inside.
burger
Erf
Last winter I built a workbench that used 4x4 pressure treated lumber for the legs. The back two legs were about 7' tall so I could hang a sheet of pegboard above the bench. The legs twisted so far that the pegboard buckled in the middle. I ended up cutting the bench apart and using the lumber to make a better bench.
jimvannoy
Mississippi
I have a big 3'x8' bench I built with treated 4x4's I had left over for the legs with 2x4 framing bolted to them. It has a big heavy steel top on it and it's holding up fine after several years of hard use.
hatchy
I built my fish tank stand out of treated 4x4s and after 5 years, it's now showing any problems. My tank weights in around 2500 pounds.
NOMAD
Should work fine for legs. As others mentioned, long runs may warp as it dries out.
I built rolling tables out of 4x4 legs and left over plywood, formica countertops etc. They're not pretty but they certainly do the job.
