Worm Drive Circular saw!
mkrug001
San Antonio, TX
The worm drive is way overkill for the weekend woodworker / family handyman type. These saws are heavy, produce A LOT OF torque, are made to rip through sheet after sheet of plywood all day long. They also require more maintenance than a your typical circular saw (require oil changes). I made the mistake of buying a worm drive first and had to get a circular after I learned from experience. I love the worm drive and I will not part with it mostly because its cool and the model I have is highly sought after (old school / made in the USA version). Save yourself some money if you're doing lighter duty cutting and get a high quality regular circular saw.
Rabid Badger
It has been almost 10 years since anyone posted in this thread. I think it's safe to say they've figured out what kind of saw to get by now.
Downwindtracker 2
BC
Depends what you are using the worm drive for. If you are cutting steel, they are a good tool, but if you are cutting plywood and you try to follow a chalk line, you end up with more curves than a beauty contest. They are utterly useless. The only way we could cut a straight line was to bump up against another sheet of plywood. This was a crew of professional carpenters working on a dam. Easily over a hundred years of experience. California framers like them because of their power, you drop it on the stud and it's cut, but framers are notoriously rough and ready carpenters. They are quick, though. A much better balanced and controllable saw is the copy of the old Skilsaw 535, the Makita 5007. You can build kitchen cabinets with them, many a carpenter has, including me.
bob15
Northeasten, CT
So what you're saying is youor your crew cannot cut a straight line with a worm drive saw?
I find worm drive saws to be the easiest saw to operate and to cut straight with.
Downwindtracker 2
BC
Yeah, a crew of eight of highly experienced carpenters. The position of the handle is critical on a Skilsaw , on the 77 it's too far back. This means because of the leverage, a small movement will cause a larger movement at the blades edge. Nor can a handle be too far forward and above like the old B&D homeowner POS. Great for picking it up in the store not so good for control. The old Rockwell and Milwaukee's with vertical post design also brought the control hand off the ideal position by lifting it up.
I guess if you clamp the wood down and use two hands..........
Wamsutta
Amarillo, Texas
Last I checked, there's no law against overkill.
the intimidator
ontario canada
to the people who can't cut straight with a worm drive or can't figure out how to drop a piece of cut wood on the left or right without using both hands and a clamp! might I suggest a safer occupation/hobby such as padded room tester or straight jacket fitment tester :lol_hitti hahaha :beer: work drives are the cats *** for any serious framing or renovations. great line of sight with the blade on the proper side without leaning over the saw (for right handed operators) enough torque and strength to rip lvl's for hours and most importantly their cool and macho if that's you're thing :pimpflash I wouldn't trade my old skillsaw for any sidewinder made
jgromada
Maryland (between DC & Balt)
I too have several circular saws. I have a Skil HD77 which is a bit heavy but if you are cutting framing lumber it is the best. So like if you are making a bunch of trusses and a bunch of wall sections it is set up and there is sort of a production going on. It excels at this heavy duty production type stuff.
I also have a a Skil sidewinder in magnesium. Nice saw, much lighter and if i have to carry it up on the ladder to make a cut it is my preference.
There are other saws i have to do particular tasks. Like i had a bunch of flooring to cut and one has a flooring blade in it. and another is best set up for plywood panels.
I think my Skil sidewinder was the most expensive at $100, my Worm drive was $25 at a yard sale (w case!) , The other saws were maybe $15 each.
I like my worm drive Skil but it is too heavy to use all the time. I'm doing a bunch of trim cutting recently and i had found an old Ryobi 6 1/2 cordless saw for like $15. That works great for the trim work, don't even have to plug it in!
2oolhound
BC Canada
My worm drive is my favorite for general use. The battery dewalt is second for quick one cut tasks. I have a few sidewinders I keep a brick blade on one and a cross cut on the other.
Wamsutta
Amarillo, Texas
I think it's funny as heck the panel saw at the HD store I work at has to have a work order put in to change the blade. Meanwhile, 10 feet away from the saw are a whole bunch of Diablo 7-1/4'' blades hanging up on peg hooks. The panel saw uses a worm drive Skil as the actual saw. Those Diablo blades would work beautifully. That's corporate red tape for you.
dnschmidt
Phoenix, AZ
As a matter of fact Bosch no longer owns Skilsaw they sold it to the Chinese. The same company that owns Flex (which is a top of the line German brand) now owns Skilsaw.
seber
Deep East Tx.
As a professional carpenter (many years ago) I used both types. Sidewinder for cutoff and worm drive for panel sawing. They each excel at one or the other. Now I have a worm drive outfitted with metal cutting abrasive blade. The abrasive doesn't bother the 77 like it would a sidewinder.
lardy1
Although they seem to have no shortage of lovers, I never liked worm drives. I spent over 30 years as a working carpenter (multiple aspects, never a dedicated framer for very long) and I could never figure out why anyone would want to handle those heavy things all day.
Downwindtracker 2
BC
A carpenter after my own heart. As young guy, I never noticed the weight factor, but the middle aged carpenters certainly mentioned that in which brands of skilsaws were their favourites.
A worm drive is a great tool for cutting expanded metal, in fact I can't think of a better one. See they do have their uses.
iamrfixit
Iowa
I've got a skil 77 and a Makita hypoid, used the skil most of the time. On the makita the brake only works about half the time, been that way since right after the warranty ran out. Also have a couple regular corded saws, haven't used them in a while.
Just got the Dewalt 60v worm drive, it's gonna be my new favorite. Caught it on sale with 9.0 battery, charger and a free bare tool for $322. I got the standard 60v circular saw two years ago and I've used it for most everything. Missed the left blade and the longer form of a worm drive so this is gonna be great.
Farmall450
Marengo, Illinois
That saw killed a Skil 77 when wranglerstar put them side by side ripping ~20' lumber. :thumbup:
iamrfixit
Iowa
Wow! I had to go hunt down the video, I've always liked my old 77, thought it was a beast.
I've only made a couple test cuts with this so far, but I love the thing. I've got several other 60v tools and I've been thoroughly impressed with every one of them. The 20v stuff is excellent, but these are like having a cord.
Farmall450
Marengo, Illinois
Me too, I was amazed at how it destroyed that Skill 77.
Hakeem
Chicago
Worm drive saws have the advantage of a motor oriented parallel to the blade. The gyroscopic forces that are produced resist turning and lead to a straighter cut. Same thing is at play with an angle grinder … fire one up and move it around, you’ll immediately notice how it resists moving in some directions.
I love Skilsaw for the heritage, the long reach, the easily visible cut line, the ability to easily cut lumber propped up off one’s foot, and the aforementioned ‘stability control’ you get from the orientation from the motor.
rust in the eye
Chicagoland
Without doubt, the best worm drive saw is the Skil HD77 in Magnesium. If it doesn't have the power to cut it, nothing will. And the magnesium case is durable and lightweight. It far outclasses the Bosch and Craftsman competitors. Also, many of the saws that look like a worm drive are actually a bevel or hypoid drive (e.g. the Makita version). Not nearly as durable, and not nearly as powerful.
Agreed
TommyK
CT
I framed for years using a 6 1/2 inch Black & Decker 3050 worm drive. Lighter and slightly more compact than a 77 which I have also used extensively. Much prefer the B&D. I still have both.
