Would this heater suit?
JJ_
GLASGOW
trovato
Putnam Valley, New York
I'm not really sure what your winter temperatures are like, or what you are trying to accomplish. Do you want toasty warm or just to take the chill out? Also, propane heaters can be vented. Then the fumes will be outside. I went with a vented propane heater. I want to be able to open the doors to move a vehicle in or out, and have the heater bring the temperature back up reasonably quickly. Electric is also the most expensive to run where I live (New York) though lately propane is no bargain either.
bmwpower
Not sure of the power requirements in Scotland, but unless you have 3 phase power to your residence, you will not be able to use the first heater.
J
JJ_
GLASGOW
The temps here go to about -10 degrees lowest here.
I just want it to be about say 15-20 degrees. Is a propane my best idea then? How do you vent the propane?
trovato
I'm using an Empire DV-55. Check out http://www.empirecomfort.com/ for more info. It vents through the wall. They show venting method pictures on that site. Your space is smaller, so you wouldn't need a unit that big. I think you need some more "local" information as to what is available to you, and what makes financial sense. This thread has certainly given me practice doing unit conversions. When I want my garage to be 20 degrees in the winter, I open the door. Oh, you meant Celsius! LOL
trovato
Note that the heater I'm talking about is permanently installed. If you're looking for more of a portable heater solution, you can pretty much ignore the stuff I said.
J
JJ_
GLASGOW
What about the gas and the detailing/car that will be in the garage. It is wooden would this not be hazordous if I have a naked flame ??
trovato
Naked flame? We keep our flames fully clothed, thank you. :) It is actually quite safe, because the combustion chamber is sealed. It takes in outside air for combustion and then exhausts to outside. It does all this through that mushroom shaped thing going through the wall. The garage is heated by the garage air circulating over this hot, sealed combustion chamber through the use of a fan. There are some diagrams on that web site.
