Yerkes-Plum broadax question
30-30remchester
I recently acquired a vintage Yerkes-Plumb broadaxe head with the poll instead of being flat, instead has a set of 3 initials cast proud onto the poll. The few times I worked as a logger we would mark the trees we fell with marked initials but with a colored grease pencil. Could this be the reason or is there another use?
5ubtle
Spartanburg, SC
I don't know the answer, but are you suggesting that the axe was cast new with the owner's initials (i.e. custom made for the buyer)?
30-30remchester
I will attempt to post photos. Ax head has 12" cutting edge and weights 6.5 pounds.
The initials were probably added after the axe was made by removing material around the letters, not by changing the forging / casting die/ thingie after each head was made.
This monkey staying out of that fray, not my area.
30-30remchester
I also had the thought that the poll may have originally been forged flat and the original owner spent considerable time removing metal resulting in his initials.
Wolley
Maine
I've seen log marking hammers only as stand alone tools. A broad axe wouldn't be used to fell or buck logs any way. There was a time where men would hew RR ties in the woods right where they cut the trees so it might be for marking ties once they were done. But I'm guessing some previous owners initials not related to any business.
30-30remchester
WOOLEY is entirely correct that this is not a falling ax but a tie hackers ax. I have actually used a similar tie hackers ax to hewn some logs for a cabin rebuild. More work that I would like to do again. The head dated from the 1860's to 1880's, correct time frame to have been used in railroad construction. NEOPHYTE, above mentioned that axes were forged not cast, which is mostly correct as I have a couple cheap hatchets that have cast heads. Mine gives all indications of being a forged head, thus in my mind the initials would almost certainly have been an after manufacture addition. Way too much hand work to just be a property owners ID marking IMO. To go back to the railroad theme, if a person got paid per piece, it would make sense to mark your work. Assuming there were falling crews and squaring crews, once the tree was felled and cut to length and delivered to the job sight. Tie hackers would get to work squaring either 1 or 2 sides before tracks could be laid upon them. This accomplished the opportunity to ID your work with a simple 180 degree rotation of your ax makes sense to me. However, I spent 36-year years standing outside in adverse weather, mostly above 8,000 feet elevation so I am quite certain that many of my brain cells received too much frost bite and never recovered.
