Due to a lack of space, I'm forced to sell my parts cleaning tank. It's a Zep Dyna Clean system in excellent working condition. Fluid is pumped through a replaceable canister filter and then into a flexible line which routes it through a scrubbing brush. There is also a replaceable filter in the drain, which means the solvent stays very clean.
The metal lid can be closed, and the drain has a grate with a seal to prevent evaporation and avoid unwanted smell in the garage when the system is not in use. Two switches on the right side of the unit control the electric pump and the built-in overhead work lamp. A shut-off valve on the left allows a relatively clean pump filter change.
The drum is filled with over $400 worth of Zep 170 solvent. The solvent is clean and clear. Included with the tank are various scrubbing brushes, soak trays, filter replacements and drum liners. I don't use the tank very often so I can't even remember the last time I had to replace a filter. It's probably been ten years.
This unit is pick-up only and is located in the Los Angeles area. I have no way to deliver it but I can help load it into your vehicle. Two people can handle it unless the unit needs to be lifted, in which case we will need either a couple extra guys or 50 gallons worth of containers to pump the solvent into.
Retail on these units is about $1,000. I will be looking to sell it in the neighborhood of $500 for everything. It's really in excellent condition both mechanically and cosmetically.
Here is a link to an add for the newer model. Mine does not have a spring-loaded lid, and there are a few other small differences. The basic unit is the same though.
http://www.rpi.co.th/psr/Dyna clean.PDF
Here are photos of the actual unit. Looks better in person for some reason.
